Steering wheel Shake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mxmaniac, Jun 25, 2010.
  1. Mar 2, 2015 at 11:18 AM
    #681
    slapmackie
    slapmackie Member
    Powell, Tn.
    2017 Tacoma TRD OFF ROAD 4X4
    I just set up an appointment with Toyota of Chattanooga to try and fix my jacked up wheels/tires. Put on brand new BFG rugged terrains 6 months ago and the shaking was so bad at highway speeds that I just quit driving it. Finally found you guys and learned of the Haweka/Roadforce, we'll see what happens. Let you guys know the outcome, fingers crossed.....
  2. Aug 4, 2015 at 9:56 PM
    #682
    clementsme22
    clementsme22 Active Member
    Matthew
    2007 Silver Tacoma TRD sport
    none
    I have the same problem on my stock 2007 4 door long bed. It happens to me around 50-70mph. I also feel vibes as I break off the freeway, so i'm gonna have the breaks checked out, and then check the lower outer ball joints. I'll check back with the results.
  3. Aug 4, 2015 at 11:42 PM
    #683
    gospurs21
    gospurs21 Well-Known Member
    Brownsville, Texas
    05 x2 Cab Texas Edition V6 prerunner, TRD
    I found it was just an alighment i needed!
  4. Aug 5, 2015 at 9:36 AM
    #684
    dudewheresmytaco
    dudewheresmytaco Member
    North Texas
    06 PreRunner Doublecab TRD Offroad
    06 PreRunner Doublecab TRD Offroad, 3" toytec lift, 16" MotoMetal Wheels, Nitto Terra Grappler Tires - 285 75 16
    Get the wheel bearings checked as well.
  5. Aug 29, 2015 at 4:39 PM
    #685
    jrsell1950
    jrsell1950 New Member
    2006 tac
    My 2006 Taco has 300,000 and just recently started having the shaking steering wheel at most any speed.
    Wheel alignment and balance did not cure. All the steering and suspension components are tight. had a good talk with my mechanic shop. Said it might be a lazy u-joint, not worn or clinking just too tight to revolve freely. I had them replace the front and rear most u-joints.
    Almost all the shaking disappeared. On a hunch, I had the transmission fluid changed and the rest of the shaking is gone.
    Not sure why this worked, but maybe someone can enlighten me how it did work.
  6. Nov 23, 2015 at 5:33 PM
    #686
    jgood98
    jgood98 New Member
    Tennessee
    05 Tacoma 4.0 6-Speed
    3 in lift, ARB bumper, Warn 8k winch
    Mine is getting pretty bad around 45 to 75 mph. but i dont want to waist money on stuff thats not going to fix it. anybody have any solution yet?
  7. Nov 24, 2015 at 9:22 AM
    #687
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I would start with tire rotation, balance, alignment, followed by driveline lubrication...
  8. Nov 24, 2015 at 7:15 PM
    #688
    jgood98
    jgood98 New Member
    Tennessee
    Okay I'll try that out thanks!
  9. Nov 24, 2015 at 7:39 PM
    #689
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    My steering wheel shakes... due to bass :anonymous:
    Ihatetacomas and Biscuits like this.
  10. Dec 7, 2015 at 7:06 PM
    #690
    TonyTacoma
    TonyTacoma Member
    Florida
    08 Tacoma
    I looked up a shop near me using the Hunter GSP9700 wheel balancer and alignment and it made a huge difference. When I went to my Toyota dealer, I had to explain all about lug and hub centric and the Haweka adaptor. I gave up and went to a place recommended by Hunter.
    Check this link to look one up near you:
    http://www.gsp9700.com/search/findgsp9700.cfm
  11. Feb 6, 2016 at 4:49 PM
    #691
    Skypearson
    Skypearson New Member
    Douglas
    Hilton Head Island, South Carolina
    2011 Tacoma TRD Sport
    You guys are great, my truck shook at any speed above 45 mph. Took it to the dealer with the Haweka adaptor and had the tires balanced. Now it is like a new truck with a smooth ride. This forum is great for information, it just takes a while to shift thru the bs. Thanks for the help.
    Biscuits likes this.
  12. May 7, 2016 at 8:44 PM
    #692
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Just got a 2015 DC 4x4 and had new tires installed. Have vibes, returned and rebalanced and still vibes. Took to local Toyota dealership today and they said 3 of 4 were out of balance so they rebalanced and guess what, still vibes. They had no idea of any adapters being used. Been a bit since anyone posted in here but it's driving me nuts. Tires are Cooper atp's.
  13. May 7, 2016 at 9:03 PM
    #693
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Ask about the Haweka Adapter. If they don't have it or use it take it somewhere else.
    TACO TX[QUOTED] likes this.
  14. May 16, 2016 at 6:14 PM
    #694
    SuperMidget
    SuperMidget New Member
    14 black taco sport
    I have the same front wheel vibrations. All the time in the steering wheel only and 70 000 km which got progressive.
    As a mechanic I figure it's tire wear combined with my wheel locks.
    Edit: stock wheels
  15. Jul 7, 2016 at 3:37 PM
    #695
    Gumby07
    Gumby07 Member
    Chelle
    SoCal
    2012 Toyota Tacoma (Black)V6 PreRunner
    None at this time
    My 2012 pre-runner started vibrating between 40-50 mph. I took it in to a shop and they claimed it was my spark plugs, so I had replaced all my spark plugs and the shake has gone away while driving. Now I'm having an issue with the steering wheel shaking as I'm breaking. Once again I take my truck in to the shop and the mechanic indicated it was my shocks/struts. So I had the hubby change the shocks/struts and got an alignment done right after (of course). But that didn't help the problem, I took the vehicle in and now it's the breaks and drums that need to be replaced!? What!!!!! I need a legit mechanic, this is insane because most parts and labor I can do, but replacing almost everything on this vehicle is getting ridiculous... The tires and break pads had been replaced only last near Nov. Tires are still good, maintenance done every 2-4 weeks. Any advice? The shake is getting to be annoying...
  16. Jul 7, 2016 at 4:07 PM
    #696
    Jimmyh
    SC
    2012 Prerunner SR5
    Either cheap brake pads and / or improper bedding of the brakes will both cause this vibration. I just took care of the exact same issue on my son's Four Runner last week. He had just replaced the brakes last December. Cheap brake pads and improper bedding was his issue.
    Some reading material: https://www.google.com/search?q=Proper+brake+bedding&ie=utf-8&oe=utf-8
  17. Jul 7, 2016 at 4:13 PM
    #697
    Gumby07
    Gumby07 Member
    Chelle
    SoCal
    None at this time
    Sounds like I might have to get both replaced then huh... Thanks for the advice and reading material...
  18. Jul 7, 2016 at 7:34 PM
    #698
    Jimmyh
    SC
    2012 Prerunner SR5
    You are welcome. I hope you get this sorted to your satisfaction.
    I agree it sounds like you need a better mechanic as the one you are using just wants to throw parts at it at your expense.
  19. Sep 23, 2016 at 9:00 AM
    #699
    Mrcarp
    Mrcarp Well-Known Member
    CT
    2022 TRD Off Road
    Not sure if this helps anyone but I had some steering wheel vibration after getting new tires put on. Final solution after lots of balancing, and second set of new tires was to tighten all lug nuts to proper torque specs using only a torque wrench and bringing the torque up a bit at a time.
  20. Nov 6, 2016 at 12:41 PM
    #700
    longspear
    longspear Well-Known Member
    Daniel
    2011 Tacoma Dbl Cab TRD Sport
    887 Full OME Dakars 4Runner Trail wheels 255/80/17
    hoping to have a solution to mine next week as well. The dealership actually made mine a whole lot worse. i'll post here if mine gets resolved. Just depressing reading all these posts about people having the same problem
    (by the way, i'm driving one of the new 2017 TRD OR double cab 4x4 and it rides smoother than my wifes tahoe!)
