Steering wheel Shake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mxmaniac, Jun 25, 2010.
  1. Aug 20, 2020 at 7:13 PM
    #721
    pinktaco808
    pinktaco808 Hot Steppa
    how i fix? replace both rotors?
  2. Aug 20, 2020 at 7:24 PM
    #722
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Rotor is not a Caliper.
    A Rotor is the Disc part of the brake.
    The Caliper is the part that clamps the brake pads to the rotor.
    Rotor:
    Caliper ( the red part on this image, usually not painted):
    Rsmallw2 and Kpatt9 like this.
  3. Aug 21, 2020 at 10:20 AM
    #723
    Turdyota3000
    Turdyota3000 Well-Known Member
    Round da corner
    07 dcsb trd off-road
    Icon 2.5's, TC, yackety shmackety....
    I have replaced the following with no avail. Wheel bearings, uniballs and bushings on UCA’s, brake rotors and pads, needle bearing
    (to ecgs bushing), lowered the front end a half inch, and tire balancing and rotation... I will admit that it is a little smoother and A LOT quieter (needle bearing or wheel bearing) but I still have a shake around the 50-60 mph range. Went to have it aligned and the tech came and got me to show me that I have a lower ball joint bad on the passenger side so I chose not to align and waste my money. Should have the new OEM LCA’s in the morning so I’m going to tackle that and report back. I’m not 100% sure that the LCA balljoint is the problem either because it did not have a whole bunch of slack. But has slack none the less.
    Edit: All of this was done this week.
  4. Aug 27, 2020 at 10:36 AM
    #724
    Skynet Surfer
    Skynet Surfer Well-Known Member
    Dis
    15 DC v6 SR
    Hood struts Weathertech floor mats Roll n lock bed cover With custom Yakima rack over the bed Poploc tail gate Bed mat Retrofit source led fog lights Hitch and or 4 pin wiring Or just random small crap!
    Does it do this right after a bump? I'm having a strange steering wheel wobble often after a bump in the road. But sometimes it does it randomly.
  5. Aug 28, 2020 at 1:36 PM
    #725
    Turdyota3000
    Round da corner
    No and it doesn’t do it all the time either.
  6. Sep 1, 2020 at 10:01 AM
    #726
    vermont
    vermont Well-Known Member
    This was the problem for me. Had a shake develop a while back around 50mph, but it was intermittent. Brakes pulsed when the shake was present, but not when it wasn't. Last week, suddenly the shaking was severe and not limited to 50mph -- but it was still intermittent.
    Found one caliper piston sticking. Replaced and all shake gone, smooth as silk at all speeds.
  7. Sep 13, 2020 at 7:09 AM
    #727
    TacoTime10
    TacoTime10 Well-Known Member
    New Hampshire
    2010 ACLB 4x4 SR5 2.7L 5MT
    2021 TRD OR wheels and tires, bed stiffeners, fog lights
    Just had a local repair shop swap tires from the stock 2010 steel wheels to some used TRD OR wheels and now my steering wheel shakes like crazy above about 60mph. Wondering if the offset is slightly different on the alloys, making it so the alignment is off or something? The shop also used the clamp on weights, maybe the balance is off?
  8. Sep 13, 2020 at 12:54 PM
    #728
    racer1x
    racer1x Well-Known Member
    campbell ca
    05 Taco
    Too many
    Do yourself a favor and dump those crappy duracraps, worst on road tire ever made. They shook the shit out of me and my truck for 5 year until I couldn’t take it anymore: multiple balances alignment everything you can think of was blamed except the tires. Once I dumped them the truck is way smoother than with those crap tires. Plus driving in the rain was soo sketchy but sorta fun cuz I got good at my drifting skills but almost wrecked every winter.
    Terrova 80 likes this.
  9. Sep 14, 2020 at 6:59 AM
    #729
    Zacowacko
    Zacowacko Well-Known Member
    Zack
    SW, OK
    2013 DCSB TE 4x4 6spd
    TRD Pro Susp., Icon AAL, Bags w/cradles, US OR Bumper w/Smitty, 2Lo Mod
    Those tires have been gone for a couple years now. So have the 5100's. No issues now
  10. Sep 15, 2020 at 5:47 AM
    #730
    Skynet Surfer
    Dis
    15 DC v6 SR
    Just did outer tierods and its better but still wobbles. Lca next I think.
  11. Sep 15, 2020 at 7:08 AM
    #731
    Zacowacko
    Zack
    SW, OK
    This is gonna sound dumb, but helped mine out quite a bit. Have you backed off the lug nuts and torqued them to spec in a star pattern as you should. I noticed mine was bad when i would get tires changed and they just hit them randomly with their impact. Do you have aftermarket wheels?
    Turdyota3000 likes this.
  12. Sep 15, 2020 at 7:25 AM
    #732
    Skynet Surfer
    Dis
    15 DC v6 SR
    I have TRD pro wheels with factory lug nuts. Torqued to 83ft. So not sure how thats going to help me with a steering wheel vibration of the tires. Feeling like they are going left and right.
  13. Sep 15, 2020 at 7:59 AM
    #733
    Zacowacko
    Zack
    SW, OK
    Do you have a lift or running stock?
  14. Sep 15, 2020 at 8:38 AM
    #734
    Skynet Surfer
    Dis
    15 DC v6 SR
    All stock, no lift. Only aftermarket parts are the new moog outer tierods.
  15. Sep 15, 2020 at 10:31 AM
    #735
    Zacowacko
    Zack
    SW, OK
    I had to get a correct alignment and torque my wheels to correct mine. I had a couple different alignments and still had the shake. Finally found a shop that knew what they were doing and since that and the re-torque i have been good. Assuming you got an alignment already?
  16. Jan 24, 2021 at 10:08 AM
    #736
    Reapacheap
    Reapacheap Well-Known Member
    Kam
    Memphis/Bay Area
    2015 TRD sport double cab
    All-pro Fox 3" lift, FN wheels, 33" general M/Ts
    Figured I'd report my solution for the next thread skimmer. Road Force Balance at the dealership and cb drop. Purs like a kitten on the highway. Have a 3" allpro kit 33's general grab.
    SR-71A and Turdyota3000 like this.
  17. Feb 27, 2021 at 7:53 AM
    #737
    matteischens
    matteischens New Member
    2009 Tacoma TRD Pro 4DR Long Bed
    Had some steering wheel shake and seat shake like many have stated. I had been doing my own tire rotations for the last year and had one balancing done at a Discount Tire. Finally went to the dealership who had a Hunter Road Force balancer for a balance/rotation and the ride is much smoother now.
  18. Mar 1, 2021 at 1:11 PM
    #738
    Zacowacko
    Zack
    SW, OK
    RF is great. I have to put eyes on it after Discount Tire tried to tell me they had one and turned out they didnt.
    matteischens[QUOTED] likes this.
  19. May 3, 2021 at 4:31 PM
    #739
    Terrova 80
    Terrova 80 Member
    James
    2015 metallic flake blue TRD off road
    I have been told that a lot of tire manufacturers actually don't make concentric tires as in the past, this has been something that I have an issue with. If you look at certain tires, you may notice that they look like they have been folded in half. This is from the manufacturers process. There are videos that shows how this happens, and being told that it's not an issue is not something to take lightly. I had several issues with the Wranglers hydroplaning and high vibrations, causing the vehicle to drift on dry pavement. I swapped them out for the Destination le and the problem was solved.
    Not all tires are a general fit. If you want the best tires for your vehicle, you need to understand the Toyota specs for your specific vehicle.
    My wife had an 1980 Camero a special order,that was wicked fast, except the factory put the wrong size tires on it, kept spinning on the beads,finally got the right size WOW! Hold on to your shirt! But the car wouldn't go anywhere in the snow. I was told she had wrong type of tires, got some Continental winter tires and no longer an issue. Tire types and sizes do make a difference.
  20. Jul 20, 2021 at 3:42 PM
    #740
    Buckless
    Buckless Member
    Twin Cities, MN
    2011 Tacoma Prerunner Double Cab
    Jumping in late on the thread, but thought my situation might benefit others. Own a 2011 Tacoma PreRunner (148K), 265/70/16 tires on factory aluminum wheels. The truck has been flawless, never had an issue with it. Recently developed a shake in the steering wheel between 60-75 mph. No shaking below 60 and mild shaking above 75. Checked the tire pressure; 27.5 in front and 28.5 in rear. Put air in until they were 29 front & 32 rear. The test drive showed that the shake was now between 65 - 75 mph. So I started reading the shaky Tacoma steering wheel threads for more information. Thanks to everyone who weighed in on them, they were very helpful.
    Took a test drive down the street with my window rolled down and heard a noise coming from my left front tire that sounded like something rubbing on every rotation. Crawled underneath to see a large patch of tar on the tread and inside sidewall of the front left tire, maybe a coffee cup or two amount. It was a 4" wide by 12" long patch with fine granules of rock mixed in. Scrubbed it with hot soapy water, wire brush, and scraped it with a putty knife. Repeated the process multiple times until most of it was removed. Rinsed off the area and tire and took it for another test drive. No shakes. This situation just shows how a single, out of balance front tire can shake the steering wheel of a Tacoma. Now I'm just waiting for the 21.5 mm socket to arrive from Amazon so I can remove my swollen lug nuts and rotate my tires. I'll finish cleaning the rest of the tar off when I remove the wheel.
