Steering wheel Shake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mxmaniac, Jun 25, 2010.
  1. Oct 11, 2010 at 3:48 AM
    #81
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    Welcome to the TW forum!
    Well written, I agree and good information. I am running Michelin MS/2's and like em.
  2. Oct 11, 2010 at 5:11 AM
    #82
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    mine does it bout 45-55 n i found out i got a bent rim...wth brand new rims n ones bent...i was pissed
  3. Oct 11, 2010 at 6:19 AM
    #83
    mharv76
    mharv76 Member
    Dallas
    2006 Prerunner
    6 in lift
    Bent rims suck, but there is no true round rim as there is no true round tire. This why the Hunter 9700 balancer is so effective when balancing larger tires and rims. It literally (when used properly) measures the "high spot" in the rim and the "high spot" in the tire and marks them on the screen. The tire technician (if properly trained and not lazy) breaks the tire down and spins the tire on the rim to offset these "high spots". This causes a cancelling effect once these out of round spots are lined up correctly. The tire and rim are then balanced again to ensure the smoothest ride possible. The only thing left is to ensure the rim is centered on the hub with hub centric rings and the ET style lugnuts I recommended in an earlier post.
    For the vibration between certain speeds, I would check the driveline angle and the U-joints. Tires can cause this, but I found on my recently purchased Prerunner I was having the same problem at certain speeds 45-55. Sure enough the U-joiunt at the very back is trashed. Picked up some Federal Mogul U joints ($25 a piece, heavy duty) and the vibration is virtually non-existant. Additionally, lifting a truck can create binding in your driveline angle. I recommend dropping the carrier bearing on the prerunner model ( not sure about the 4X4 setup). For the 6 inch lift on mine I added a 1 inch spacer on the carrier bearing. I recommend a half inch for every three inches of lift (suspension lift). This should keep the angles pretty close to stock. When you tighten the carrier bearing back up, make sure the driveshaft is lined up laterally (left to right) between the tranny and the rear end. You can buy these spacer kits premade or run down to Home Depot and get longer bolts and washers (get the stout bolts, grade 8 or better if doing it yourself). The washer method works well for mild lifts (1-2 inch), but for 3+, I 'd use the prefabbed. You can pick these up from toytec for a little over 10 bucks. No one thing suggested will fix your vibration problems, but I feel if you use a combo of these things, you can eliminate 99% of the vibration on your trucks and enjoy that comfy ride from the factory, even with a lift. Good luck friends!!
  4. Oct 19, 2010 at 11:44 PM
    #84
    akwagon
    akwagon Alaska Dude
    chris
    alaska
    08 Access 5spd 4x4
    5100, kazktin leather, truxedo
    Same thing here... How to fix!!!
  5. Oct 20, 2010 at 5:55 PM
    #85
    supermunn5
    supermunn5 New Member
    Ben
    Saratoga Springs, NY
    2009 SR5
    Just bought my 09 last month with 20,000 miles with stock Dunlop's. 60 mph + had a slight shake, brought back to Toyota, tires rebalanced, still shook, new Dunlops, still shook, new BF Goodwrich coming in this week. Better fix it! Truck is stock so far so not sure what is causing it. According to dealership, common problem and the Dunlops are suposedly the problem across the board. We'll see.
  6. Oct 28, 2010 at 5:53 PM
    #86
    93civEJ1
    93civEJ1 Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
    mine shimmys a little bit, but it doesnt bother me.
  7. Oct 30, 2010 at 6:41 AM
    #87
    DionysiosA76
    DionysiosA76 Captain Analyzer
    Dionysios
    Barrington, IL
    07 Taco Sport DC 6 spd-SOLD FOR CUMMINS
    Totally custom straight pipe exhaust sourced from an 01 Cummins (fabbed up by yours truly), ScanGaugeII, Westin Bull Bars, air horns, Truxedo tunneau, Black decals, Black rotors, black calipers, Secondary Air filter removal, reengineered dirtbike hauler, auxillary back up lights, blacked out tail lights, socked by Sockmonkey, blacked out hi-stop, TRD stickers (+300hp :) Owens Running Boards, Greek flag shifter, Garmin Nuvi 755w GPS, Cobra 25ltd CB with a 4' fiberglass whip... and never paid anyone nuttin to do it.
    I get some vibration when I race **** around my school... but thats from 20-110mph, and for dropping the clutch spinning 5k in 4HI... yea i beat the shit out of it, but its a toyota pickup, it just doesnt break.
  8. Oct 30, 2010 at 4:29 PM
    #88
    pinktaco808
    pinktaco808 Hot Steppa
    same hurrr
  9. Oct 31, 2010 at 5:17 PM
    #89
    tacobale
    tacobale Well-Known Member
    Just DUMPED my 09 Tacoma at a used car lot for this same problem that TOYOTA couldn't fix or wouldn't fix!!! I was not going to take any more of there BS and I figured I wasn't going to fight with Toyota anymore about this when MANY if not all TACOMAS have this problem!!! So I lost money and TOYOTA lost a customer for LIFE!!! And I tell everyone I know about this!!!!!!!!!!!
  10. Nov 2, 2010 at 3:49 PM
    #90
    Thomas Lee
    Thomas Lee Shogun
    work truck
    3" lift
    I had that proplem with a T100 and all it was, was the right side seaf springs had shifted causin the rear end to seesaw. But a shop told me that it was cuz the rear wheels were lockin up and the front was draggin them. My friend had a slightly similar problem and it was cuz his spare tire underneath was loose and rockin back and forwarth. just take the rear wheels off and make shure everything is tight.
  11. Nov 3, 2010 at 6:38 PM
    #91
    toast
    toast Well-Known Member
    Same problem:
    09 Prerunner
    Hankook DynaPro ATM RF10 P265/75/16
    Konig Countersteer Offroad
    Gorilla spline nuts.
    Rear spring TSB done
    Front 1/2 of the DS replaced
    I was told the shake was because the footprint of the tire is much wider than stock, or some crapola.
    Advice?
  12. Nov 3, 2010 at 8:00 PM
    #92
    tacobale
    Live with it OR dump it. I couldn't live with it so I took the latter.......
  13. Nov 3, 2010 at 8:04 PM
    #93
    1bad10tacoma
    1bad10tacoma Well-Known Member
    Mark
    Brewer Maine
    2025 dcsb Trd off-road
    tonneau,
    I had this problem with mine, but it went away after the leaf spring TSB was done. Good Luck
  14. Nov 5, 2010 at 6:21 PM
    #94
    Creemore
    Creemore Well-Known Member
    Toronto
    Magnetic grey TRD Sport/leather pkg.
    I just switched out my OE Bridgestone summer tires, and put on my Michelin snows. Poof... vibration gone. With the 'stones on the truck, the slightest bit of gnat poop on a wheel or in a tread would make the truck act as if it had thrown a balance weight. The Michelins are covered in mud and snow, and still run the way they should. My verdict, for me at least, is the tires. The Bridgestones are sold, and a new set of real tires is going on in the spring. FWIW...
  15. Nov 5, 2010 at 6:24 PM
    #95
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    So I take the truck, turn it on, turn wheel all the way to one side and the rack should move by itself? Or does someone have to push pressure the opposite way you have the wheel turned?
  16. Nov 8, 2010 at 5:31 PM
    #96
    MiniManAbear
    MiniManAbear Active Member
    Louisiana
    07 Access Cab
    DC Audio, Rockford Forsgate, Eagle Eye halos
    I just put some 20" Helo's on and I have the same problem. From about 45 - 65 MPH, my steering wheel shakes..
  17. Nov 14, 2010 at 9:47 AM
    #97
    RTRIZED
    RTRIZED New Member
    Larry
    Clarksburg, WV
    TX Pro
    Just bought a 2011 TX Pro and had the same problem between 60 and 70 mph. Took it in and the dealership ended up dismounting and remounting the tire. Now the problem is gone and the truck rides unbelievably smooth.
  18. Nov 15, 2010 at 9:59 AM
    #98
    WV_Tacoma
    WV_Tacoma Well-Known Member
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    You could put tires craved from stone it it and never have this problem....I have flipped the truck over, rotated the cuffs, spanked the rear and lubed the tail pipe and....new tires and wheels, still rides like a little muffy mobile......I have never heard of suck issue from a big truck......some isolated but never like these.....
    TOYOTA, put a real front end on these things.....
    TOYOTA CUT the fender wells out to fit a BIGGER TIRE THEN, barbie mobile tires....
    thank you, thank you very much
  19. Nov 15, 2010 at 12:19 PM
    #99
    08pretaco
    az
    drove this morning when cold and it was much much worse than ever
  20. Nov 15, 2010 at 9:53 PM
    #100
    rsxftw
    rsxftw Well-Known Member
    Tyler
    Santa Cruz
    09 DCSB TRD Off-Road
    Mine did this on the stock tire/wheel setup. got my new tires and wheels much much less, 50-55 i get a little shake, then really nothing.
