Steering wheel shaking badly help please
Discussion in 'Wheels & Tires' started by francis1291, Jun 9, 2011.
  1. Jun 9, 2011 at 3:36 PM
    francis1291
    francis1291 [OP] Well-Known Member
    10 4x4 SR5 super white
    3" procomp lift wit 20" rockstars on 33 toyo mt's
    I have 33's toyo mts on 20's. I bought the tires and rims when I had 10,000 miles on the truck now I have 30,000 my problem is when im going 40-50 my steering wheel shakes like crazy. I had them balanced that were on the front when this started to happen and it still didn't help. This is the weird part. Before I rotated them the steering wheel was not shaking but that was 5000 miles ago and I just got them rotated back to the position they were before when the wheel was not shaking but after I drove it today its still shaking. Any1 have any help with what is going on? I need this shaking to stop
  2. Jun 9, 2011 at 3:48 PM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    One of your front tire is uneven. You can check by running your hand on the tire, to see if it swell up. I have the same problem. Alignment shop won't cure your problem.Time for a new tires
  3. Jun 9, 2011 at 3:52 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Are you even sure it's the tires? Have you checked your tie rod ends? Turning 20's can be hell on tie rods Jack up your truck and see if you can move the wheel from right to left.
  4. Jun 9, 2011 at 3:55 PM
    97Blk_one
    Memfrica
    not so low
    On mine that's what cause it. I got 4 spangin' new tires, the shaken gone.
  5. Jun 9, 2011 at 4:02 PM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    Let's be honest... you really only care about your own rig.
    I'm having the same issue but it has almost gone away. I ran my KM2s too long without rotating and they started cupping bad. Now I get them rotated monthly and keep the alignment perfect and it has almost completely gone away. When I replace these bad boys, I will be religious about rotating. I never had this issue when I ran A/Ts, but all mud terrains are notorious for this.
  6. Jun 9, 2011 at 4:19 PM
    francis1291
    Why is it time for new tires when I just put the tires the way they were before all this shaking happened. The good tires were at the rear but I don't understand what could have happened to the good tires when they were at the rear.
  7. Jun 9, 2011 at 4:22 PM
    francis1291
    You think my tie rods could be bad with only the truck being lifted for only 20,000 miles. That's when I put the lift and tires on.
  8. Jun 9, 2011 at 4:30 PM
    francis1291
    But I rotate mine every 3,000 to 5,000 miles. They couldn't get my alignment perfect because of the ball joints.
  9. Jun 9, 2011 at 4:36 PM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    get a road force balance done, that will cure any tire balance issues. but as said previously, your turning a very heavy wheel and tire combo so you could have worn tie rod ends. 20k miles is a lot more than what is needed to wear shit out if its overloaded
  10. Jun 9, 2011 at 4:37 PM
    JLee
    Jerry
    Bay Area NorCal
    I'm not saying there bad I'm saying to check them out before you go drop a bunch of money on new tires
  11. Jun 9, 2011 at 4:41 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If your rim is tweaked, or a belt is broken in the tire, all the balancing in the world will be of no consequence.
    Bad ball joints will cause the tire(s) to wear unevenly, but not cause balance issues. When the ball joint finally separates, you will have other, more pressing, issues! Replace the ball joints!
  12. Jun 9, 2011 at 5:29 PM
    97Blk_one
    Memfrica
    not so low
    I dunno. I just though that were the case. On mine I rotated often, at one point it shaken badly, So I took it to the alignment shop, the guy told me ,that shaken on the steering wheel won't solve the problem. I got home took the tire off and observe,scrutinized, viola... one side of the tire swelled up. Replaced the tire. Solved
  13. Jun 9, 2011 at 8:13 PM
    francis1291
    i had it road force balanced when it started doing it and they balanced them and as soon as i left it was still doing it.
  14. Jun 9, 2011 at 8:15 PM
    francis1291
    i didnt mean to come across as being smart or anything i just want to get this crap fixed. it drives me crazy!! im going to get them all balanced when my next check comes in and if that dont fix it then ill try the tie rods
  15. Jun 9, 2011 at 8:18 PM
    francis1291
    but when i was headed home tonight i was going 60 ish and it stopped shaking. only does it 40-55 ish. i wonder why it stops at +60
  16. Jun 10, 2011 at 12:42 PM
    francis1291
    Little update. Went to get all my tires balanced and had them check all the front end and they drove it and says it still does it. There is nothing wrong with tires or rim. No coupling or anything. Any1 know what is going on?
  17. Jun 10, 2011 at 12:44 PM
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    that happened to me too,when I rotated the tires I got a bad shake,my tires were pretty worn
  18. Jun 10, 2011 at 1:33 PM
    francis1291
    What did you do to fix it?
  19. Jun 10, 2011 at 1:41 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Ah, one other idea I forgot to mention: make sure they do a lug-centric balancing and NOT a hub-centric. Any respectable tire shop should know that. I had my wheels balanced at the Discount out by me, they must have not done it right because I took it to a different Discount later that same week when it was still vibrating and they got it dialed in. Told me the balance was way off after the other Discount told me it was almost perfect. Problem was gone immediately. There's a special tool they use to balance by your lugs instead of the center of the rim. Make SURE they balance your Taco that way, and ask them to show you.
