Step by step removal and installation of e-locker 3rd member
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MonkeyProof, Dec 19, 2011.
  1. May 18, 2013 at 7:30 PM
    #181
    MonkeyProof
    MonkeyProof [OP] Power Top
    SoCal- SGV
    I waited no time to add the fluid, never had any issues with leaks. But I'm sure others will chime in to say to wait a few hours for the RTV sealant to cure :cookiemonster:
  2. May 18, 2013 at 7:33 PM
    #182
    munkel
    munkel fka unregistered lurker...
    PDX
    2004 Dbl Cab V6 4WD Tacoma
    Icon Suspension, 285/75/16 BFG MT's, Steeeckers, Custom Bed Mounted Tool Storage, Wilderness Trail rack, SoftTopper, K&N CAI, Hella Aux lights, PIAA Fogs, Warn M8000, Elite Front Bumper, BAMF sliders, All-Pro leafs and shackles
    Thanks MonkeyProof!
  3. May 18, 2013 at 7:38 PM
    #183
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    You've done this enough times, maybe you can answer my question. I used your method of unbolting the brake line hangers so i didnt have to crack the lines and after i got everything bolted back up i noticed my back brakes were rubbing horribly before i hooked the ebrake back up. i had to go inside the drums and adjust everything so they dont rub when im not on the brakes, but now it feels like i dont have any back brakes and my is at full adjustment and its barley grabbing. Just seeing if youve ever run into this issue
  4. May 18, 2013 at 7:41 PM
    #184
    munkel
    PDX
    check the angle on your rear brake proportioning valve maybe?
  5. May 18, 2013 at 7:44 PM
    #185
    MonkeyProof
    SoCal- SGV
    I have never had this issue before. And unless you disassembled the brake shoes to remove the ebrake cable I don't know what the issue would be.
  6. May 18, 2013 at 7:52 PM
    #186
    munkel
    PDX
    Thanks, I was worried because the instructions stated:
    "Finger tighten until material begins to squeeze out around flange. Allow to dry for one hour then retighten 1/4 to 1/2 turn. 4. Silicone will skin over in one hour and fully cure in 24 hours under normal conditions. Allow more time for cold or very dry conditions."
    I was worried I had to wait 24 hours since there would likely be some RTV in the rear end.
  7. May 18, 2013 at 7:53 PM
    #187
    4banger4x4
    Eric
    Whorelando, Fl
    i never touched the drums. all i did was pull each axle out and slide them back in. Its pissing me off and im gonna end up buying a disc conversion because of these stupid drums
  8. May 19, 2013 at 6:21 AM
    #188
    4banger4x4
    Eric
    Whorelando, Fl
    Yes. I'm not a complete fuck tard
  9. May 19, 2013 at 7:59 AM
    #189
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    ^ :laughing:
    Dive in reverse real fast and slam on the brakes... should set the rear... although not positive this works on our trucks
  10. May 19, 2013 at 8:27 AM
    #190
    munkel
    PDX
    No one said or thought you were.....until now. :cool:
  11. May 19, 2013 at 10:25 AM
    #191
    MonkeyProof
    SoCal- SGV
  12. May 19, 2013 at 10:40 AM
    #192
    munkel
    PDX
    So I just filled and was going to go for a test drive, ABS and rear locker light are on. Hmmmm. I know I moved the fork back over, maybe it didn't seat correctly. Any thoughts?
  13. May 19, 2013 at 10:46 AM
    #193
    MonkeyProof
    SoCal- SGV
    I woukd make sure that the connectors are pushed in all the way, you shojkd have heard and felt a click. Also, have you tried to engage and disengage the locker while driving? It would be safe and harmless to do on pavement if driving in a straight line. You can also remove the locker motor to try and move the fork again.
  14. May 19, 2013 at 10:52 AM
    #194
    munkel
    PDX
    Thanks, will try all of that.
  15. May 19, 2013 at 11:35 AM
    #195
    munkel
    PDX
    So this guy I know followed the directions real well when they were in red, he however didn't follow the part about shifting the fork back after the install of the 3rd. What a dumbass he was..... :annoyed:
    Thanks for the help!
  16. May 19, 2013 at 11:39 AM
    #196
    MonkeyProof
    SoCal- SGV
  17. May 19, 2013 at 1:45 PM
    #197
    4banger4x4
    Eric
    Whorelando, Fl
    oh trust me i know. and it normally is the simple stuff that gets over looked
  18. Jun 22, 2013 at 9:17 AM
    #198
    Haws
    Haws Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
  19. Jul 18, 2013 at 11:15 PM
    #199
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2003 TACOMA DC OFF ROAD
    35'S ON 3s
    Good read! Thanks for sharing. Im doing this tomorrow with an arb 3rd into my sport
  20. Jul 25, 2013 at 5:22 PM
    #200
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    This was easy squeezy :) Just followed it step by step, and I did the whole thing in just a couple hours.
