Step by step removal and installation of e-locker 3rd member
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MonkeyProof, Dec 19, 2011.
  1. Apr 22, 2017 at 8:02 AM
    #341
    TEEIAM
    TEEIAM Well-Known Member
    2013 TACOMA
    Nice write up, thanks for the information...
  2. Jun 23, 2017 at 9:11 AM
    #342
    Jcogtacopr
    Jcogtacopr Member
    07 Tacoma TRD offroad v-6 silver
    None yet
    Kind of disturbing that the ring and pinion gears dont seem to hold up well on these trucks. Maybe underdized gears for the wt of the truck? Or offroad driving rough on it. Just curious what problem could be!
  3. Jun 23, 2017 at 10:51 AM
    #343
    la0d0g
    running for the hills
    For crawling not hauling
    They're plenty strong but skinny pedal takes its toll sometimes.
    greeneggsnspam likes this.
  4. Jun 23, 2017 at 1:37 PM
    #344
    Jcogtacopr
    Jcogtacopr Member
    None yet
    Oh, ok.well u guys put up some great info on all this stuff. Im still learning about these trucks and am very thanklful with any info i get. So great job, esp since u have done it offroad. Very impressive.
  5. Jun 27, 2017 at 2:07 PM
    #345
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    @MonkeyProof Don't know if it was mentioned before in the thread, I'm mid install right now, taking a quick break. Something I thought of doing that's working good and has pro's and cons...jack the truck up, put on jack stands, jack rear axle enough that the tires are about an inch off the ground, jack stands under the axle, lower axle enough so the tires are just baaaaareeelly off the ground, then when you pull the axles out, the tires hold the axles up and out. Just something I'm trying that seems to be working fine. Pro's don't have to take the tires off. Con's not as much room under the truck to work, but I'm not super cramped.
    GilbertOz and MonkeyProof[OP] like this.
  6. Jun 27, 2017 at 2:08 PM
    #346
    VolcomTacoma
    Jeff
    NorCal
    Also, diff was waaaaay worse than I thought, finding chunks of metal, ring gear is chunked. Glad I stopped driving it last week when I heard howling from the diff!
  7. Jun 29, 2017 at 2:30 AM
    #347
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Thanks to this thread, got my 3rd out, sent it out to ECGS along with my nitro 4.88 gears and master install kit, got it back in less than a week (nearly $400 just for shipping) and got it back together. Thanks again @MonkeyProof :cheers:
    Gonna be turning 37s so I'm gonna have to baby it till I can afford a 9.5" diamond for the rear.
  8. Aug 18, 2017 at 9:51 AM
    #348
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Going to be following along with these instructions in a few weeks.
  9. Aug 18, 2017 at 11:19 PM
    #349
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    pulled my axles out to pull my third today and gear oil came out of one end...
    i proceeded to check the drums and no leak and pads are dry so im assuming its the inner seal that is bad? any experience from someone who has dealt with this or has changed them out?
  10. Oct 6, 2017 at 5:09 PM
    #350
    MTyota86
    MTyota86 Well-Known Member
    Haverhill, MA
    09 TRD Off-Road
    Airaid Intake, Magnaflow Exhaust, Diff Breather, SOS Concept Sliders, OME 3" Lift, SOS Concept rear bumper, Plasti-Dip grill and Badges.
    Great write up.
    Have any of you had problems getting the e-locker out? I tried to pull the locker out tonight but was unable to. Unbolted the three bolts holding it on and pried it as far as it would go, but it doesn't seem to want to come out. Judging by the pictures in the first post it should just pull right off. Am I missing something? It gets almost half way out and then feels like something is pulling on it. I don't want to force it the rest of the way and break something because I'm just trying to fix the locker.
  11. Oct 6, 2017 at 5:13 PM
    #351
    inesshell
    with a flat head go in and try to nudge the gears loose? had this happen with a friend when we were swapping his out but we just kept wiggling it around until it let out
    la0d0g likes this.
  12. Oct 6, 2017 at 5:25 PM
    #352
    la0d0g
    Sometimes it binds up on the bolts. Like John said, just keep wiggling it and it'll come loose.
  13. Oct 6, 2017 at 5:50 PM
    #353
    MTyota86
    Haverhill, MA
    09 TRD Off-Road
    Thanks guys. I'll give it a shot again in the morning. Like I mentioned, I didn't want to go from bad to worse. Good to know that it can stick.
  14. Nov 25, 2017 at 1:36 PM
    #354
    617mike9c1
    617mike9c1 Well-Known Member
    Newton, MA
    2008 DCLB Sport 4wd
    A little of this and a little of that
    Thanks OP for the how-to... this is REALLY helpful, especially with the pics.
    Trying to swap in a new third member my the driveway before it gets too cold and the part I got stuck is when you need disconnect the axles from the housing and pull them out a few inches... I needed to sacrifice a sharp wood chisel to break the bond between the axle housing and the bracket after the four 14 mm nuts are removed. I guess after 80k miles of New England weather, things tend to fuse together a bit. The some Kroil, a sharp chisel and 4lb sledge hammer did the trick.
    I should be able to finish her up tomorrow. Thanks again!!
    MonkeyProof[OP] and Red Demon like this.
  15. Feb 11, 2018 at 4:37 PM
    #355
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    Thanks for the write up! I used it today and wouldn’t have known to switch the locker to locker to get the new third in.
    MonkeyProof[OP] likes this.
  16. Feb 12, 2018 at 7:32 AM
    #356
    Red Demon
    Red Demon Well-Known Member
    Vinnie
    Kennett Missouri
    07 SR5 4x4
    Tinted windows Upgrade to New 2014 radio Weather Tech Front Lift:2.5 ICON Extended Travel Coilover Shocks Icon Uni Ball Tubular UCA Rear Lift: Icon 1.5" AAL ICON 2.0 Aluminum Series Rear Shock Relentless Front Bumper Relentless Rear Bumper SOS Sliders and skid plate
    Thank OP for the write-up ,helped me install an ARB locker this past weekend
  17. Mar 9, 2018 at 6:25 AM
    #357
    Adventurous
    Adventurous Well-Known Member
    Colorado
    15 DCLB SR5
    I'll chime in and say thank you as well! Working by myself and I got the old 3rd out and the new one installed in a couple of hours.
    Now to tackle the front.
  18. Apr 17, 2018 at 5:04 PM
    #358
    Adrian.Brewster
    Adrian.Brewster Well-Known Member
    Adrian
    2020 trd off road
    So I just pulled the 3rd member out of my first gen. The bearings had gone bad and it was grinding like crazy. I pulled the diff out and brought it to a shop to be rebuilt with new bearings. I put it back together last night with some cheap 80w90 oil because the auto parts store had closed and that’s all Walmart had. The truck runs and sounds great now, but when I drained the oil to fill it with some good stuff, the oil had a ton of metal shavings in it. Like, a ton. Is this normal when breaking in new bearings? The oil looked metallic.
  19. Apr 26, 2018 at 10:23 AM
    #359
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Need clarification from the 1st page - do we need to mark the drive shaft and pinion flange?
  20. Apr 26, 2018 at 10:34 AM
    #360
    MonkeyProof
    MonkeyProof [OP] Power Top
    SoCal- SGV
    Not neccessary
    JoeTacoma02[QUOTED] likes this.
