step on brakes dash lights come on
Discussion in '1st Gen. Tacomas (1995-2004)' started by mikemars, Oct 29, 2009.
  1. Oct 29, 2009 at 9:24 AM
    mikemars
    mikemars [OP] Member
    vancouver island
    trd
    just as the title states. the lights on the heater controls as well. i searched but couldn't find anything. anyone else had this problem. no changes to the truck recently ie stereo etc. im thinkin fuse maybe, but thats just a guess. cheers.
  2. Oct 29, 2009 at 9:31 AM
    tacotopher
    tacotopher Well-Known Member
    Memphis
    Zombie TRD OR
    Grey wire mod, 5100's on all four corners, AAL in the rear, deckplate mod,
    Check all of your bulbs front and rear. My wrx was doing the same thing. Find out one of my taillight bulbs did not have a good connection.
  3. Oct 29, 2009 at 10:01 AM
    mikemars
    vancouver island
    trd
    oh wait come to think of it i did replace my whole left rear taillight assembly with an aftermarket one about two months ago. after doing some more searching i think your right that will probably be the culprit. when it stops pouring i will try swapping the bulbs out for the old ones.
  4. Oct 31, 2009 at 10:52 AM
    Air_Ops
    Air_Ops Active Member
    Peter
    N.W. VT
    01 Ltd Dbl Cab
    TRD Headers, Cat Back Exhaust, Airaid Intake Tube, LC Engineering Throttle Body Gasket, Bilstein 5100 Series Shocks, Wheeler's Add-A-Leaf, LC Engineering Tundra Brake Kit, Re-Framed
    If you have a pigtail connector for a trailer, then it has gone bad. If you read the rating on the regulator you will find that most trailers with non-led lights exceed the allowable draw for the regulator. I am on my third one for my 01. I pull a small (5'x8') enclosed trailer and the combination of 4 side markers, 2 taillights, and a license plate light, and that exceeds the recommended draw for the regulator. The easy way to test is disconnect the pigtail and see if the dash lights are still coming on when you apply the brakes.
  5. Nov 20, 2009 at 8:09 PM
    mikemars
    vancouver island
    trd
    so i finally got a day with no rain so i finally made it outside to do some troubleshooting. turns out it was the bulb in the taillight i replaced. changed the cheap chinese bulb for a genuine GE 1157 and problem solved. thanks for the insight.
  6. Nov 20, 2009 at 8:11 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    sounds like some crazy backfeed
  7. Feb 10, 2013 at 6:21 AM
    DixieDog
    DixieDog Member
    2010 Tacoma
    I used the Curt T Connectors about 3 years ago. Would that present the same issue?
    Never mind. After disconnecting all is well. I reckon' I'll have to get a new set every 3 years.
  8. Feb 10, 2013 at 6:30 AM
    DixieDog
    DixieDog Member
    2010 Tacoma
    Yes. I've got the same issue on a 2010 Toyota Tacoma 4WD. How did you solve your problem?
    Curt T connectors that were installed 3 years ago for trailer lights were the issue. Evidently the black box others have mentioned went bad.
  9. Feb 10, 2013 at 8:23 AM
    vtrguy
    vtrguy Well-Known Member
    Jarrod
    Chico
    '01 Taco TRD xCab SR5
    Deckplate, Full OME kit, Snugtop Camper, Camry ignition ring, TRD Catback
    see Post #5
