Step rails question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Low_&_Slow, Nov 14, 2019.
  1. Nov 14, 2019 at 8:50 AM
    Low_&_Slow
    Low_&_Slow [OP] Well-Known Member
    Leland
    Lacey, WA
    2018 LB DB TRD OR
    Snugtop rebel canopy
    Will a DB SB steps fit a DC LB? Found some local for very cheap. TIA!
  2. Nov 14, 2019 at 9:07 AM
    docsg
    docsg Well-Known Member
    South Alabama
    2020 White TRD OR SBDC
    Raptor 4" oval rails, OEM door sill protectors, totally debadged, OEM mud guards, OEM bed mat, OEM S/S tail pipe extension, BDT tailgate letters, Weather Tech sun screen.
    I assume they would as I believe the cab part of the SB and LB are the same. I think the difference would be if it is a DC or AC. But, don't go to the bank with my advice...that and $1.00 will buy you a Coke at McDonald's (assuming that special is still available).
  3. Nov 14, 2019 at 11:53 AM
    CementHead18
    CementHead18 Well-Known Member
    Jim
    SC
    2018 CementTRD Sport 4x4 DCSB
    I ordered steps from the dealer for a DCSB and when I picked them up learned they were for a DCLB, my mistake as I gave them the wrong part #. Anyway, they were longer than the steps I needed and knew right away by the length of the box. Tried one anyway and did not fit. Ordered the right ones and no problems.
  4. Nov 14, 2019 at 1:01 PM
    piff
    piff Well-Known Member
    Minnesota
    2019 Quicksand Tacoma TRD OR DCLB AT
    Bone stock baby
    since the back wheel on a dual cab long bed is farther back there are different mounting points than a dual cab short bed.
  5. Nov 14, 2019 at 1:08 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    A dcsb and dclb pre drilled holes are the same. I have a set of predator step bars and they came off a dcsb and went directly into my long bed. They all allign right up and running boards from a 2nd gen will bolt right up as well.
  6. Nov 14, 2019 at 1:08 PM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    looks like they have different part numbers.
    Part Number:
    PT767-35110 (B-CAB REGULAR BED)
    PT767-35111 (C-CAB REGULAR BED)
    PT767-35112 (D-CAB SHORT BED)
    PT767-35113 (D-CAB LONG BED)
    PT767-35120 (C–CAB REGULAR BED) CHROME
    PT767-35121 (D-CAB SHORT BED) CHROME
    PT767-35122 (D-CAB LONG BED) CHROME
  7. Nov 14, 2019 at 1:27 PM
    dilbert
    dilbert AI Member
    PNW
