Stereo Installation Hints and Tips
Discussion in 'Audio & Video' started by NeoMoose, Jan 22, 2010.
  1. Jan 22, 2010 at 6:15 AM
    NeoMoose
    NeoMoose [OP] Possibly Batman
    Houston, TX
    2010 PreRunner DC TRD O.R.
    Kenwood eXcelon X993, Kenwood KFC-1693PS (Front), Kenwood KFC-G1620 (Rear), Luverne Black Nerf Bars, OEM Brush Guard, AFE Pro Dry S Drop-In, Some kickass wheel locks, Removed front mud flaps, All windows tinted, Anti-theft tailgate mod
    So I am tacking my install of a Kenwood Excenlon X993 tomorrow morning. Any last minute hints and tips on things I should know? This is my first stereo install I am going to tackle myself so paranoia is starting to set in.
    I think the thing I'm worried about most is getting the wiring harness correct and then finding a place to run the bluetooth mic.
    The wiring harness has a LOT of wire. Did you guys trim your wires down? I bet if I crimped it all together now my wiring harness would be over a foot long!!
    If you have any awesome tribal knowledge, pass it along!!!
  2. Jan 22, 2010 at 8:05 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Did you purchase a wiring kit that would plug into the existing connectors of the truck's wiring harness?
  3. Jan 22, 2010 at 8:21 AM
    NeoMoose
    Houston, TX
    Yeah, I have the full set of gear that Crutchfield includes with their installs. I'm ready to go!!
  4. Jan 22, 2010 at 8:29 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    Be careful with tools around the gray plastic part of the dash. It scratches really easy.
    The hardest part of my HU install was changing the clock/hazard light part from the OEM radio to the dash kit. It was just a PITA to get out. Just keep fiddling with it, but be gentle. Using a very small flat screw driver to gently pry the clips open helped me.
  5. Jan 22, 2010 at 8:33 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    It should be a simple process to match the color of the Radio Harness wire to the color of the truck harness wire for each wire needed. I would solder the connection and insulate with shrink wrap tubing.
    A big plus is documenting the colors and connectivity on paper prior to starting.
  6. Jan 22, 2010 at 8:35 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    X2
    Mine was a real PITA. I think it helps to have 3 hands to do the job.
  7. Jan 22, 2010 at 8:37 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    As others have said, just match the colors and you'll be good. Getting the damn clock out is the hardest part.
    I wouldn't shorten the harness though. Reason being is that the ORM harness wires are short and wont let you pull out the unit very far before having to unplug it. Keeping the wires a little longer makes it easier to put in. You should have plenty of room in there anyways. There is lots of room UP so don't focus on stashing the wires DOWN.
  8. Jan 22, 2010 at 9:33 AM
    NeoMoose
    Houston, TX
    Ok, good deal. Now I just need to figure out Bluetooth Mic placement. I'm poking around at other people's installs, maybe I can figure out how to get it all the way to the driver side pillar!!
  9. Jan 22, 2010 at 10:08 AM
    ItalynStylion
    Steven
    DFW, Tx.
    I actually ran mine up the passenger side A-pillar (over the glove box) and along the ceiling and terminated it just out where the rear view mirror exits the headliner. I did this for three reasons.
    1. It's the same distance from the driver as the A-pillar so it will sound the same.
    2. It's fairly well hidden up there.
    3. The passenger can talk just as well as the driver.
    If it's the same parrot mic that most units have just sandwhich it between the wire cover for the mirror and the headliner. It will stay put.
  10. Jan 22, 2010 at 10:10 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I clipped my bluetooth on the head liner to the left of the driver visor, bordering the windshield, ran the wire to the left, down the A-pillar and under the dash
  11. Jan 22, 2010 at 11:58 AM
    NeoMoose
    Houston, TX
    That does sound a whole lot easier. No problems whatsoever with the sound quality, talking way over from the driver seat? Do you have a pic so I know EXACTLY what spot you're talking about?
  12. Jan 22, 2010 at 12:41 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Uhhh, I had to pull mine out (they sent me a bum Pioneer unit) when I sent it back. The sound quality was great. I think most units you can also turn up the volume on the mic too if it's ever an issue. I'm pretty sure the distance is similar so there shouldn't be much difference at all. Besides, there will be less sound reflections than if you mounted it in a corner.
  13. Jan 22, 2010 at 4:21 PM
    JBTuncc
    JBTuncc Well-Known Member
    Charlotte, NC
    05 TRD Sport DC 4x4
    I mounted mine in the compartment under the radio on the drivers side corner. It does ok from what they tell me. You can adjust the mic volume on the 993. Congrats on a great headunit! I put mine in that compartment b/c it was easy to install right there at the radio. I may move it later if I get time but it seems to be ok there.
  14. Jan 24, 2010 at 9:35 AM
    NeoMoose
    Houston, TX
    Lot of panic for nothing. Install went off without a hitch.
    "That was easy!"
  15. Jan 24, 2010 at 9:49 AM
    SACTOWN
    SACTOWN ???????????????????????
    Greg
    '18 ZR2, 04 Rubicon, &19 lx570
    Pictures!!!
    Anyway, good thread!! This should be sticky!!!
    Good Job
  16. Jan 24, 2010 at 1:30 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    :worthless:
    WTG and Congrats. The first install is always the hardest. One more install and you will be a pro. ;)
  17. Jan 25, 2010 at 6:25 AM
    NeoMoose
    Houston, TX
    I'm going to eventually post a full writeup with quality pics, but there's a blurry taste from the cell phone.
  18. Jan 25, 2010 at 7:12 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Looks really nice and the color matches the existing interior illumination. ;)
