STERING CLUNKS IN ROUGH TERRAIN
Discussion in '2nd Gen. Tacomas (2005-2015)' started by C1pdlr, Nov 10, 2017.
  1. Nov 10, 2017 at 5:19 AM
    C1pdlr
    C1pdlr [OP] New Member
    2010 Grey DD
    2010 double door clunks and steering wheel turns slighty when driving over rough terrain. Any suggestions
    ChadsPride likes this.
  2. Nov 10, 2017 at 5:20 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Had an alignment done lately?​
    Key-Rei likes this.
  3. Nov 10, 2017 at 5:22 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Mine does this a tiny bit too, there's a slip yoke in the steering wheel that has tiny (like .5mm) play, then your rack guide could be worn, then your inner tie rod links, outer tie rod links, and ball joints, and wheel bearings can all come into account for responsibility.
    There's going to be some slop, knock, and bump, that's the nature of the beast.
  4. Nov 10, 2017 at 5:22 AM
    C1pdlr
    2010 Grey DD
    Truck was just purchased with full check done on truck.
  5. Nov 10, 2017 at 5:23 AM
    Key-Rei
    Key
    Florida
    I notice this is your first post, welcome, and what's the history on the truck? Owners, miles, location etc.
  6. Nov 10, 2017 at 5:24 AM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Does NOT mean that the alignment is proper. Take it to a reputable offroad shop in your area and have them do an offroad alignment on it. something like 3-3.5* caster, little bit of (-) camber and no toe should be just about right.
    blu92in99 and ChadsPride like this.
  7. Nov 10, 2017 at 5:26 AM
    Key-Rei
    Key
    Florida
    That doesn't mean sugar honey ices tea. My truck had a "full check" on it from the dealer, they had it listed that my timing belt was over due for replacement, the 1GR has a chain...
    But still even with everything new you will have some play offroad. It's normal.
    ChadsPride and stevotivo12 like this.
  8. Nov 10, 2017 at 5:27 AM
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
  9. Nov 10, 2017 at 5:27 AM
    stevotivo12
    Stephen
    Yeah. If you really want to minimize or eliminate the symptoms youre talking about, the best bet is really BIG tires, and a really nice 3" suspension lift with UCAs.
  10. Nov 10, 2017 at 5:29 AM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    Mine does it every day. Annoying but seems to be common from what I've read on here
  11. Nov 10, 2017 at 5:50 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
  12. Nov 10, 2017 at 6:05 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Zip tie mod
    Doogz, ChadsPride and Key-Rei like this.
  13. Nov 10, 2017 at 7:25 AM
    C1pdlr
    2010 Grey DD
    Thanks guys.The theory behind the zip tie fix makes sense but there must be a better way to insure longevity. I am a owner of
    a Tool and Die Shop here in Ontario Canada which has all the latest CMM and CNC equipment to come up with a proper fix.
    I will keep you posted as to my findings
    Ted Steel and TXpro4X4 like this.
  14. Nov 10, 2017 at 7:57 AM
    Kerrigan911
    Kerrigan911 Well-Known Member
    Dan
    05 TRD OR, AC, 4x4, V6
    i had a lot of clunks and bangs. A common failure is the steering rack bushings. I pulled the rack to replace mine (urethane ones) but ended up replacing my rack as it was pretty rusted and a PIA to get out (wasn't putting back the rusted one that was 12 years old!). I got an alignment from a small shop afterwards and no more noise. Im not sure if it was the bushings or the alignment but noise is gone so i dont care.
  15. Nov 10, 2017 at 7:58 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    zip tie mod...... easy quick and id bet it fixes your issue...... fixed mine for the last 4 years!
  16. Nov 10, 2017 at 8:04 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    :popcorn: would love to take the tie out!
  17. Nov 10, 2017 at 8:05 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Welcome to T.World!
  18. Nov 10, 2017 at 1:01 PM
    Northern Taco
    Fyi zip tie did nothing for me
