stick shift shakes!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by panardo, Oct 16, 2017.
  1. Nov 28, 2017 at 10:02 PM
    aknickyota22
    aknickyota22 Well-Known Member
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Bilstein Suspension, All Pro Baja Bumper, and more
    Mine does the same thing. Pretty common problem. There are a few bushings in the shifter assembly that start to disintegrate over time. The bushings themselves are pretty cheap to replace, but you do have to take basically the whole console apart along with the shifter. Heres a video that shows you how to do it.
    https://www.youtube.com/watch?v=lCY6XyxJjv4&t=757s&index=134&list=FL43qgGqAyE1yGmqnS6RddbA
    Dalandser and vettehigh[QUOTED] like this.
  2. Nov 29, 2017 at 5:17 AM
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
    Wonder what the cost to have that done would be? Dealership labor cost too?
    Edit: Just called dealer...they want $200
    Anyone know the part #'s I would need? 95 Extended cab 4x4 Auto V6
  3. Nov 29, 2017 at 6:14 PM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    I found a couple places that sold the same Marlin parts that had cheaper shipping. I believe LC Engineering was one, and the other was yota something or other.
    Bruno#131[QUOTED] and Dalandser like this.
  4. Nov 29, 2017 at 9:43 PM
    aknickyota22
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    I believe the OEM part number is 33501G. You can also get them on Amazon, but a Toyota dealer will probably have them cheaper.
    https://www.amazon.com/APDTY-Automa...TF8&qid=1476283466&sr=1-1&keywords=apdty+tbar
    Honestly, I would save your $200 and do it yourself. Doesn't seem overly complicated to me, but to each their own I guess.
  5. Nov 29, 2017 at 10:29 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  6. Nov 30, 2017 at 5:08 AM
    vettehigh
    Jon
    Upstate, NY
    Thank you. And I would just need 2 total pieces right?
  7. Nov 30, 2017 at 10:10 AM
    vettehigh
    Jon
    Upstate, NY
    Dalandser[QUOTED] likes this.
  8. Nov 30, 2017 at 10:11 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Sorry I was on another thread with manual shift bushings being discussed - posted to the wrong thread :(
    If you want OEM for a cheap price ask @gunny1005 he'll set you up.
  9. Nov 30, 2017 at 10:21 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I told them about USPS flat rate before they I ordered my Short throw shifter from URD. It wasn't an option in their menu but they were fine adding it for me and I ended up paying like six bucks to get it shipped to me.
    That said, how much trouble do you wanna go thru to save what? $3.50?
    Dalandser likes this.
  10. Nov 30, 2017 at 10:48 AM
    Bruno#131
    Bruno#131 Member
    2016 sport ssm dclb 4x
    Yea I called to make sure they wouldn’t just throw it in an envelope and put a stamp on it but nope can’t do it. For goodness sake it’s a couple ounces
  11. Dec 1, 2017 at 7:11 AM
    vettehigh
    Jon
    Upstate, NY
    Just ordered them from the dealer. Set of 4 was $4.75 total
    OEM part #90385-11003
    I believe there are 2 bushings on top and 2 more below, is that correct?
    Now, whom will I get to do all 4 bushings :fingerscrossed:
  12. Dec 1, 2017 at 10:17 PM
    aknickyota22
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Yep, there are 4 bushings total. I can't remember their exact location in the shifter assembly, you'd have to look at one of the videos on YouTube.
    If you can't do it yourself, I would take it to your local mechanic. The dealership will most definitely overcharge you for labor.
  13. Dec 4, 2017 at 12:45 PM
    vettehigh
    Jon
    Upstate, NY
    I think I found any easier way, but I do not believe it will cause any harm. Might just slide out over time.
    I had a thick washer and I was able to wedge it under the t-bar (it's either part #33511C or #33530F) for a nice tight fit. There is very little room, but if you get a thick metal washer, you should be fine
  14. Mar 29, 2018 at 10:17 AM
    panardo
    panardo [OP] Well-Known Member
    Taco 2000 4x4 V6 manual w/RDlock
    Thanks for the input, Speedytech7 !
    So i did replace the whole drive shaft now, and and still trying to fix center bearing height and alignment (still shakes at 70 mph mainly). Replacing rear springs and shocks made a huge difference on the ride, but the levers are still breakdancing all around...
    Now about your quote, how hard is to replace body mounts?
    Transmission mount will be a future choice to replace...
    Which are the other drive train rubber mounts? engine's? center bearing? any other?
    And yes I'd like to replace bushings and seats of gear and transfer case levers, do i need to get two bushings and two seats if I want to fix transmission and tc levers? would you mind to share those pics of yours?
    Thanks for sharing your knowledge, you did help me a lot!!!
