stick shift weird noise ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kagmyster00, Feb 24, 2010.
  1. Feb 24, 2010 at 2:59 PM
    kagmyster00
    kagmyster00 [OP] Well-Known Member
    Mark
    05AccessOffroad
    ok I have a 2005 tacoma v6 4.0 manual 6sp i have noticed when im driving my stick shift makes a rattling noise when its in gear now if im driving in 3rd and i push it up a little bit with my hand it will go away but when i take my hand off it will come back almost like it is resting on somthing any suggestions
  2. Aug 25, 2010 at 1:01 PM
    TacoJohn
    TacoJohn New Member
    Sandy, Oregon
    08 Tacoma SR5
    I have the same issue with my 2008 Tacoma 4.0L V6. When I put it in 3rd gear, it starts rattling. kagmyster00: Your post was awhile back. Did you find the cause?
  3. Aug 25, 2010 at 1:10 PM
    tvbd56
    tvbd56 Epic Member
    Tyler
    Sacramento, Ca
    2018 Black DCLB OR 4x4
    I think that's just how it is cause mine does it too
  4. Aug 25, 2010 at 3:21 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    These shifters have internal rubber bushings that wear out. My guess is the shifter is getting a little sloppy as well.
    Key-Rei likes this.
  5. Mar 15, 2011 at 12:36 PM
    Tacoma206
    Tacoma206 Well-Known Member
    Seattle
    2010 Super White 4WD
    Mine starting doing it today for the first time :(
  6. Dec 13, 2012 at 4:12 PM
    lilgeneral007
    lilgeneral007 Member
    Tennessee
    SR5 TRD 6-speed Manual
    I have this same issue, which is why I searched & found this thread. My shop got advice from a local Toyota dealer that it was the rubber bushing - so they replaced it. No noise at first, but noise showed up same day I got it back - day later it is worse. Does anyone have any success with this?
  7. Nov 19, 2013 at 8:28 PM
    BRVCKBLVCK
    BRVCKBLVCK Member
    Canada
    TRD
    3inch lift
    My shifter was good all summer but now when I'm in 1st 3rd and 5th it makes a plastic on plastic rattleing sound.. Any ideas?
  8. Dec 29, 2013 at 1:01 AM
    xx99sublime89
    xx99sublime89 Member
    steve
    San Diego
    05 trd off road prerunner 6 speed
    k&n intake, billet grill, in dash navigation, component speakers, 4 channel amp, flowmaster exhaust, JBA headers
    ive had the same issue did a lot of research. and all i got was its the motor and tranny mounts going bad. i replaced that bushing and got no help. i havent tried the mounts yet
  9. Sep 23, 2022 at 6:41 AM
    nuzzbutter
    nuzzbutter New Member
    Joe
    2015 Access Cab, TRD Off Road, 6 Spd Manual
    Is there any update on this? I've also got a pretty concerning rattle while my shifter is in gear and resting on it's own. If I use my hand to lightly push forward on the shifter, the noise is gone. Is the rattling coming from the transmission? Throwout bearing?
  10. Sep 23, 2022 at 7:05 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    One thing to check is the shifter boot. Some times the plastic ring at the top of the boot rattles on the shifter. Next time it rattles, just grab the top of the shifter boot and see if it goes away.
    mojojojo78 likes this.
  11. Sep 23, 2022 at 10:54 AM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    The rubber isolator between the inner and outer stick is likely worn out and sloppy. As such, you're hearing the NVH (noise vibration harshness) from the transmission/gears vibrating through the shifter when the inner stick contacts the outer stick.
    There's a guy on here that bores out all the old rubber and pours poly in there to fix this issue. A bit of searching will find him. (if you search for short shifter, he's posted in those threads a lot) If you pull the shift boot and look at the shifter it'll be obvious.
  12. Sep 23, 2022 at 11:09 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    I am the "GUY".
    shaeff[QUOTED] likes this.
  13. Sep 23, 2022 at 11:10 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    If the internal bushings are shot, there will be a lot of slop in the shifter.
  14. Sep 27, 2022 at 5:29 AM
    shaeff
    Hudson Valley, NY
    Damn I just couldn't remember your username!
    @nuzzbutter if your isolation bushing in your shifter has deteriorated, hook up with @Coupe - He does nice work!
  15. Oct 5, 2022 at 2:50 PM
    Big Red 2nd Gen
    Big Red 2nd Gen Well-Known Member
    Dan
    Red 2008 TRD Access Cab 6 Speed
    TRD Cold Air Intake, Fat Bob's Vated Bilstein fronts set at 3 inches, stock rear leafs with ICON progressive multi leaf "add a leaf", MBRP Stainless dual exhaust, Sport Hood with scoop, Pedal Commander, Pro Comp 16x8 wheels with 265/75R16 KO2's, toneau cover.
    What's it take to get one of these done?
  16. Oct 5, 2022 at 3:01 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    $120 + shipping.
