sticker and badge removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chopperjones, Dec 12, 2011.
  1. Dec 12, 2011 at 2:15 PM
    chopperjones
    chopperjones [OP] Member
    10' Tacoma DC TRD
    whats the best way to remove trd stickers on rear quarter panel, how about the badges?
  2. Dec 12, 2011 at 2:20 PM
    DevilDogTacoma
    DevilDogTacoma Well-Known Member
    Maryland
    2010 Tacoma V6 DCSB
    Flowmaster 40 Muffler, 15% Front Window and Windshield Sun Strip Tint, Antennax 14" Antenna, OME 3" Lift w/AAL, SlimCubby 6000K HID headlights and foglights, Thule tailgate pad for surfboards, 285/70/17 Nitto Terra Grapplers on 17x9 XD Addicts, LED map, dome and tag lights
    never removed the decals before, but I've taken some badges off my tailgate. I used a hairdryer on the badges for a few minutes to soften the glue/tape, then I took fishing line and pulled it between the tailgate and the badge and it cut right through the glue. I had to scrape my tailgate a little to get the rest of the glue residue off, but it came off pretty clean for the most part
  3. Dec 12, 2011 at 2:20 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Blow dryer for the decal, warm it up and start peeling and for the badges use the blow dryer to soften the adhesive and then use fishing line to saw between the glue and the truck. Use glue be gone or a similar product to remove the residue.
  4. Dec 12, 2011 at 2:23 PM
    sean266
    sean266 Mr. Clean Moderator
    This. Worked for me
  5. Dec 12, 2011 at 2:23 PM
    Shep6924
    Shep6924 Active Member
    Navarre, FL
    '11 TRD Sport Debadged
    Side steps/nerf bars, iPod interface! Bug/rock deflector (removed!), 3" bilstein coilover 5100 & add-a-leaf, 1" diff drop! 1.25" spidertrax spacers, Light racing UCAs
    I'm getting ready to do that in about five minutes. I read the same thing as ^ I also heard dental floss works well...it's a cheaper option than going out to get fishing line if you don't have any on hand. Get some goo gone while your at it. Good luck
  6. Dec 12, 2011 at 2:24 PM
    Eltacos
    Eltacos Well-Known Member
    BFE CA
    TRD Off Road
    LED conversion on every accessible bulb, TRD exhaust (dealership threw in for free along with the Blu-Logic).
    I had my TuRD stickers off the day I came home with the truck. Just peel really slow and they come off in one piece. I have yet to de-badge my truck.
  7. Dec 12, 2011 at 2:25 PM
    beerye
    beerye Steel Curtain!!
    Brian
    Tucson, AZ
    02 TRD 4x4 5spd
    3" suspension lift 2009 Tacoma Alloys K&N Intake
    I am planning on doing mine this weekend as well so let me know if the dental floss works! Sounds like a good idea to me!
  8. Dec 12, 2011 at 2:28 PM
    chopperjones
    10' Tacoma DC TRD
    does goo gone f up the paint?
  9. Dec 12, 2011 at 2:28 PM
    bendbolden
    bendbolden Come and take them.
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    I don't imagine floss would work well. If you are sawing the fishing line / floss it is going to get hot and break. I went through a few pieces of fishing line doing mine for that reason but who knows maybe floss will work.
  10. Dec 12, 2011 at 2:30 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    No it won't hurt it. I wouldn't let it set overnight or anything but just be sure to clean it all off when you get done. It pretty much works instantly on the glue.
  11. Dec 12, 2011 at 2:40 PM
    Fiolo
    Fiolo Senior member
    98 Regular cab lifted 4wd
    Lost track many mods ago
    Looking for some 2nd gen badges If anybody doesn't want them pm me
  12. Dec 12, 2011 at 2:43 PM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
  13. Dec 12, 2011 at 3:22 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Goo Gone works.
  14. Dec 12, 2011 at 3:44 PM
    Shep6924
    Navarre, FL
    Just finished and I'm debating on the decals. Haven't pulled them yet, but the badges came off pretty easily. I let the Goo Gone sit for about a minute on each spot and then the remaining glue came right off. "Clean as a virgin's honey pie"
  15. Dec 12, 2011 at 3:45 PM
    Shep6924
    Navarre, FL
    I ended up using fishing line cause I had some available. It broke several times but not bad.
  16. Dec 12, 2011 at 3:45 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Stickers = heat + goo gone
    Badges = heat + fishing line + goo gone
  17. Dec 12, 2011 at 4:21 PM
    beerye
    Brian
    Tucson, AZ
    02 TRD 4x4 5spd
    Cool, thanks for the info!
    Should make it a lot easier, now that I know what to use!
  18. Dec 12, 2011 at 4:34 PM
    SPENCAF
    SPENCAF Well-Known Member
    Shiloh, IL
    2012 TX PRO 4X4
    AFE Pro dry filter, AttennaX, bed liner on front skid plate, AVID sliders, AVID light bar, KONG Storage Box, OME 2.5" 885 coils 1.5" AAL 265/75R16 Guard Dawgs
    How old of fishing line are you guys using??? I've debadged before and never ran into the line breaking.
    Maybe because I was using 65 lbs mono. :p
    blow dryer works best, if you use a heat gun be careful I've seen guys F up there clear coat with a heat gun.
  19. Dec 12, 2011 at 4:38 PM
    markc6606
    markc6606 Well-Known Member
    Pompano Beach
    '13 Off-Road
    I used cotton bailing twine. I tried both the fishing line and dental floss and both kept breaking. Just keep the badges nice and warm and make sure it's cotton twine (nice and soft, no scratches whatsoever) and one piece did all my badges.
  20. Dec 12, 2011 at 4:38 PM
    Shep6924
    Navarre, FL
    Had some 10lb laying around. I recommend something stronger...
    Decals gone!
