Stiff clutch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by robsam, Jun 28, 2012.
  1. Jun 28, 2012 at 10:17 PM
    robsam
    robsam [OP] Truck Norris
    Rob
    Surrey BC Canada
    07 dbl cab sb 6sp
    3" procomp lift Raider canopy Fog light control mod Aluminum boat rack Rear ubolt flip kit Stainless extended rear brake lines Drive shaft bearing spacer Front diff drop Spidertrax spacers Cooper at3 tires 285/70/17 GTA ipod interface unit Rcds204 4x4 illuminated switch
    My 07 4.0 seems to have a very tough clutch to depress. When I brought the truck to the dealer to have a front wheel bearing changed, they lubed up the linkage and it was better for a week. Now it's back to being tough. It can't be stiff springs because it was better after they lubed it. Is mine the only one or do others share this too. I'd rather push a stiff clutch than not have one at all
  2. Jun 29, 2012 at 10:26 AM
    gofast
    gofast Well-Known Member
    I've found brief discussions on other forums about this, but haven't seem to found a clear solution.
    Here's a quote from a marlincrawler post:
    "My 96' has a relatively stiff clutch, but no leg press... If I were you I'd first try servicing the clutch pedal assembly(replace and grease the $20 or so worth of little bushings, maybe the spring if it's cheap, then bleed the system). Don't forget to check to make sure the slave cylinder(attached to the tranny) has grease on it's plunger where it contacts the clutch fork. Here's a link for servicing the pedal assembly. http://www.lieblweb.com/tacoma/Mechanical/ClutchPedal/ClutchBushing.htm If that doesn't work, replace the cylinders, if that doesn't work, you just wasted your money on parts that probably would have lasted the life of the yota."
    I've been looking at a 05' tacoma 5-speed which takes a lottt of effort to depress the clutch - I'm taking it into a dealer tomorrow for a "pre-buy" inspection and I'll ask about the clutch.
  3. Jun 29, 2012 at 11:49 AM
    PaintDrinkingPete
    PaintDrinkingPete Well-Known Member
    NoVA
    2012 4x4 TRD Sport DCSB
    My 2012 manual seems to be a bit stiffer than any other clutch I've owned (including a few Toyota trucks in 80s and 90s), but certainly not to the point where it affects driving...I'm talking a very small amount of stiffness that I probably only notice because I've driven a lot of manual transmission vehicles.
  4. Jun 29, 2012 at 12:48 PM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    The size of the engine is related directly with the size of the clutch that is required to handle it.
  5. Jun 29, 2012 at 1:23 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    And clutch size has no direct correlation to pedal pressure...
  6. Jun 29, 2012 at 6:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The pressure plate does however. A larger clutch has a larger and usually stronger pressure plate springs.
  7. Jul 2, 2012 at 10:16 AM
    gofast
    So I took the truck (2005 Tacoma Regular Cab 4-cyl. 5-speed) into a local Toyota dealer to have the clutch checked out. They found nothing wrong - the dealer was terrible though, and I would never go back there for anything (Toyota of Whittier) so unfortunately I don't have a fix. All the mechanics that felt the clutch said it was much stiffer than any tacoma they've driven, but had no suggestions on what was wrong.
    This truck supposedly has the original clutch (current owner bought it from CarMax w/under 30k and it now has 77k), with the service records not indicating any clutch work. Clutch has been this stiff since 30k.
  8. Feb 27, 2013 at 2:19 PM
    chadoll
    chadoll Active Member
    I have the same problem with my 2005 X-runner. It has the toughest clutch of all manual vechicles I've ever driven including the old Army trucks when I was in the service.
    Is it simply due to the size of the clutch? My Frontier was not anywhere this tough. What parts should I try lubricating?
  9. Aug 2, 2020 at 8:02 PM
    Jdm4292
    Jdm4292 Well-Known Member
    Joe
    2009 DCSB 4.0 6MT
    Any resolution to this? I’m about to undertake post #2 go fast quoted
