Stiff ride after lifting
Discussion in 'Suspension' started by knightofzero, Mar 29, 2020.
  1. Mar 29, 2020 at 11:00 PM
    #61
    Taco-Obsessed
    You could strap on a "spacer" :anonymous:
  2. Mar 29, 2020 at 11:02 PM
    #62
    knightofzero
    knightofzero [OP] Well-Known Member
    @08BajaBoy The rim is 20x10 -18 offset and true but than it looks too tall for taco they dont look right being that tall lol seem some 6in tacos and not a really a fan of it or at least for a mid size truck.
  3. Mar 29, 2020 at 11:28 PM
    #63
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    @knightofzero actually, i think you might be okay and not need the wheel spacers (if my math is correct). But to be sure, have the shop lift the truck so the suspension can fully droop. Then look to see if the rim/tire contact the UCA or the spindle. I doubt they will but always good to check.
  4. Mar 30, 2020 at 5:40 AM
    #64
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    I would go with the Maxtrac Spindle and a new leaf spring at the rear. You can easily achieve a 5" lift with excellent drive ability with this setup. The spindles will kick out the front 3/4 inch on each side. I have the Maxtrac on my truck with the Dakar Leaf Spring in the rear, Fox shocks and 33's. I also used a Spidertrax 1 1/4 wheel spacer in the rear to balance out the look. My setup has been on the truck for over 80,000 miles and drives fantastic! The Nitto Trail Grapplers will have over 100,000 miles on them before they need to be changed.
    knightofzero[OP] likes this.
  5. Mar 30, 2020 at 5:44 AM
    #65
    ChadsPride
    Sponsored by TacomaWorld.com
  6. Mar 30, 2020 at 10:55 AM
    #66
    knightofzero
    For the shocks how tall are they 3in fox shocks or coilovers ??? And how is the ride quality?? Nice truck btw @sgtnewundies
  7. Mar 31, 2020 at 3:06 AM
    #67
    sgtnewundies
    Eric
    14 trd sport red
    Ride quality is fantastic! I have the Fox coil over in the front and Fox resi in the back. Thanks!
  8. Mar 31, 2020 at 3:50 AM
    #68
    knightofzero
    What setting do you have your coilovers??
  9. Apr 1, 2020 at 3:10 AM
    #69
    sgtnewundies
    Eric
    14 trd sport red
    Its at zero lift which gives my truck about a 1/2 rake.
