still debating the best way to lift my truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hawkeye12, Aug 17, 2010.
  1. Aug 17, 2010 at 9:12 PM
    hawkeye12
    hawkeye12 [OP] Go Pack Go!
    Bryce
    Raleigh, NC
    10 Black DC SB Tacoma TRD Sport
    Smittybilt nerf bars
    Alright guys, I have been going back and forth trying to figure out which would be the best way to go about lifting my taco around 3". I have thought about doing the 5100's, but also am looking at just a standard 3" revtek. Just trying to narrow down my options. Can I still do the Revtek with the rear AAL even with the TSB?
    thanks guys.
  2. Aug 17, 2010 at 9:13 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Definitely stick with the 5100's and stay away from the Revtek, as that is a spacer lift and is not nearly as good as 5100's or a coilover lift.
  3. Aug 17, 2010 at 9:18 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    If you go offroad any, dont get spacer's. They ride pretty stiff.
    5100's only give 2.5" of lift. And if looking for a 3". I would suggest some OME Lift coils and shocks. Or you can even pair the coils up with the 5100's.
    And NO, I think the Revtek AAL is for stock leaf packs. Not the TSB one's.
  4. Aug 17, 2010 at 9:21 PM
    hawkeye12
    Bryce
    Raleigh, NC
    Okay, thanks. To obtain max lift between the 5100s and TSB, should I just set the rear and front at their max settings? Also, I do not want to do any trimming so would I be best running 32's or can I fit 33's?
  5. Aug 17, 2010 at 9:22 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    there are no settings on the rear 5100s
  6. Aug 17, 2010 at 9:27 PM
    hawkeye12
    Bryce
    Raleigh, NC
    I always thought you could set the rear to 2"?
    Wait, nvm. Read it wrong. :eek:
    :pout:
    Are the rears really necessary then if I am running the stock billies on my TRD?
  7. Aug 17, 2010 at 9:28 PM
    tbturner47
    tbturner47 Well-Known Member
    Hickory, NC
    '16 Barcelona Red TRD Off Road
    Thats what your looking for for the rear
  8. Aug 17, 2010 at 9:28 PM
    Bz3r0
    Bz3r0 Smackalicious!
    Bryan
    Edwards AFB, CA
    White 2017 TRD Offroad
    Under Construction
    I've been looking into this also... What were you looking at? I'm currently eyeballing the "Ultimate Lift" off of Toytec.com... :wink: I'm itching to get home and actually start some of this when i get back from overseas.
    Heres the link to Toytec's "Ultimate Lift":
    http://tinyurl.com/29eyq6x
  9. Aug 17, 2010 at 9:29 PM
    Incognito
    VA
    The rears aren't necessary, but most folks just go ahead and change them out while they doing the fronts. The stock bilsteins and the 5100's are different shocks (with the 5100's being better).
  10. Aug 17, 2010 at 9:29 PM
    The_Hodge
    SC
    if you are running less than 2" lift in the rear, then the rear 5100s arent "needed", but it will smooth the rear out some
  11. Aug 17, 2010 at 9:38 PM
    Rich Beauregard
    Rich Beauregard Well-Known Member
    Rich
    New London, CT
    17 Taco 4x4 SR5 Access Cab White
    Go with Old Man Emu (OME) you can find great deals on complete kits at: www.trdparts4u.com when you get to website, enter: Toyota, Tacoma, 2010, OFFROAD then click: We offer recommended components in one stop!....Suspension Kits or you can click on: Build your own Suspension with.....Suspension Components
    I just did a front this past week. Very easy to do yourself.:
    08-10-10004B_df45dd2fcf116e29a3467f11fbc796ef3530cb5a.jpg08-10-10014_dbcff24d4b9ca97daccb8a18a4dd331c287d544b.jpg
  12. Aug 17, 2010 at 9:41 PM
    musty40
    musty40 Well-Known Member
    Alan
    Duluth, MN
    2010 DC SB TRD OR
  13. Aug 17, 2010 at 9:49 PM
    Rich Beauregard
    Rich
    New London, CT
    musty40 Wow! $249 for blocks and spacers? Seems very steep. I'd avoid, but if you are going with blocks and spacers, I have an old set of aluminum spacers that I originally put on my Tacoma about 3 years back. Just the front spacers. They have been collecting dust in my shed. I'll sell them for $50 plus shipping. I'll try to take a picture tomorrow and post it.
  14. Aug 17, 2010 at 10:28 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    i have an OME coil lift (no top spacer) and 5100's set at .85. i paid about $400 for shocks and coils. i also have camburg UCA's that cost me another $400. truck sits a little over 3" and rides great, alot better than any spacer lift.
  15. Aug 17, 2010 at 11:24 PM
    hawkeye12
    Bryce
    Raleigh, NC
    Well... I decided, for now I am going to just run the 5100s up front at .85 with the rear TSB. Should I be able to clear 32's with no trimming?
  16. Aug 17, 2010 at 11:40 PM
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
    Yes
  17. Aug 18, 2010 at 3:57 AM
    64Wildcat
    64Wildcat Black Jeep of the family
    Denis
    New Hampshire
    2015 Rubicon
    I've got the 5100's set at 1.75, the tires are 265/75/16, i also have the tsb.
    Denis
