Still have the clunking noise at driver's side front tire
Discussion in '1st Gen. Tacomas (1995-2004)' started by robbymartin, Mar 17, 2011.
  1. Mar 17, 2011 at 10:52 AM
    robbymartin
    robbymartin [OP] Well-Known Member
    Rob
    Tacoma, WA
    2019 TRD Off Road
    I need help figuring this out. There is no clunk on smooth dips but if I hit a small pot hole or bump in the road I get the clunk. So far I had 2 shops confirm that my ball joints are good so what else could it be? I just had both front axles replaced so could the issue be caused from something the garage did? Everything seems to be tight. :confused:
  2. Mar 17, 2011 at 11:02 AM
    rjclemen
    rjclemen Well-Known Member
    Riley
    Charlotte, NC
    07 Pre Runner The good looking Blue
    Tint, Bed Cover, HIDs, stubby antenna, double din system, debagded, All Terrain bedside stickers.
    My tacoma has been making noises like this from the day I bought it. Just gonna have to turn the music up bud. Pretty sure nothing is going to randomly fall off your truck.
  3. Mar 17, 2011 at 3:07 PM
    robbymartin
    Rob
    Tacoma, WA
    2019 TRD Off Road
    It's not a annoying little rattle to shake off, this is a clunk. And my truck is a 4x4 so I don't need to be stranded if something is about to break if I'm offroad.
  4. Mar 17, 2011 at 3:40 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Tie rods(inner and outer), rack, rotten rubber bushings. Keep looking...
  5. Mar 17, 2011 at 4:54 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    what about the lower ball joint? did they inspect it as well. i dont know if it makes a clunk when worn out or not just throwin it out there. there is a recall on them to BTW.
  6. Mar 17, 2011 at 8:53 PM
    robbymartin
    Rob
    Tacoma, WA
    2019 TRD Off Road
    I'm not sure if their check of the ball joints was conclusive of the upper and lower. Do you check them the same way?
