still having EGR problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by dustinclm, Mar 17, 2011.
  1. Mar 17, 2011 at 8:16 AM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    i have a 2001 2.7l tacoma and As I stated in other posts, I've been havin problems with my EGR valve being stuck open, PO402 CEL code, I took off the valve cleaned it to where I could apply vacuum and the valve inside would move up and down. After fighting with air leaks, it's back on the truck but after 1/2 a tank th CEL came on again. since i know the valve can move, what could be causing the problem? not enough vacuum? the valve is still getting stuck because it is still too dirty?
    I don't know what else to try and I'm tired of taking it off and replacing gaskets and what not. any ideas would be helpful. thanks guys
  2. Mar 17, 2011 at 9:46 AM
    dustinclm
    Thibodaux, La
    could I spray some wd-40 in there to lube it up and help it open and close easier?
  3. Apr 26, 2011 at 6:03 AM
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2015 4WD DCSB
    I'm having the same problem. I have a 2.7 L 2001 Tacoma PreRunner and I got the Error code 'P0401 - ECH has detected too little flow in EGR system.' I've taken the EGR off and cleaned it, cleaned out all the hoses, replaced the gaskets and everything else I can think of, other than replacing the EGR itself. I don't know what the problem is. I'm hoping that the EGR is fixed and I just need to reset my engine light.
  4. Apr 26, 2011 at 6:57 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    ever single vehicle that I have owned that had EGR issues was due to the lines being plugged.
    Even if you "think" you have cleaned it all out belive me there is more. The worse one was a 2000 Civic HX the entire EGR track inside of the intake was plugged. A 91 Sidekick was plugged from one end all the way to the other.
    You have to remove all the lines and insure they are clear from one end to the other.
    Chunks are coming off and getting caught in the valve causing it to stay open.
    I HATE EGR SYSTEMS!!!!
  5. Apr 26, 2011 at 7:26 AM
    dustinclm
    Thibodaux, La
    well i took my EGR off multiple time and cleaned with sea foam deep creep and WD-40 and took off all the line and made sure they were not clogged but the CEL would still come back on so finally i gave up for a while and then about 2 weeks after i had cleaned it the CEL randomly went off on its own and hasnt come back on and my Ultraguage hasnt detected any problems. so maybe it just takes a while to the truck to realise it is working correctly again, who knows
    *make sure you replace the gaskets and make sure there is no leaks...
  6. Apr 26, 2011 at 7:39 AM
    brelandt
    Terry
    Dublin, CA
    seafoam and wd40 WILL NOT clean it out. Believe me it is caked on there and is otherwise as hard as a rock and chemicals will just not remove it. I had to use rods and brushes and even knives to get my EGR's clean.
  7. Apr 26, 2011 at 8:50 AM
    dustinclm
    Thibodaux, La
    you are right, everything was caked in there and pretty solid, but i used the seafoam and wd-40 and scrubbed with everything from tooth brushes to my wire brushes i use to clean my gun barrels...no more CEL means it worked for me
  8. Apr 26, 2011 at 8:54 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    congrats on the fix :thumbsup:
  9. Apr 26, 2011 at 8:58 AM
    dustinclm
    Thibodaux, La
    thanks, it was a pain in the ass to take the EGR off so many times but it was a learnign experience and it worked, eventually haha
  10. Apr 26, 2011 at 5:43 PM
    brelandt
    Terry
    Dublin, CA
    It was for me as well! Good job! :D
  11. Apr 27, 2011 at 5:48 AM
    zacharypaul89
    Zach
    Georgia
    2015 4WD DCSB
    I used carburetor cleaner to clean the EGR (let it soak for about 2 hrs) valve and pipe cleaners to clean out all the tubes, as well as replacing the gaskets and my problems seem to be fixed. If your light doesn't go off, you may need to reset it by unhooking the negative battery terminal for about 5 mins.
  12. Apr 27, 2011 at 7:08 AM
    dustinclm
    Thibodaux, La
    i had reset that light every time i pulled the EGR off to try an fix it, it always came back on, so once i knew it wasnt a valve issue or a vucuum issue, i just left it alone and then it magically went away on its own and never came back...
  13. Apr 27, 2011 at 9:10 AM
    mx04taco
    mx04taco Well-Known Member
    Cory
    Marietta,GA
    04, SR5, TRD, 4wd
    Flowmaster exhaust, Pioneer DVD HU, Pioneer speakers all around, , Viper security w/ remote start, Tinted Windows, Silverstar Headlights, Toytec 3" Coil Springs, All Pro Offroad Diff Drop 3/4", Bilstein 5100s, 2" Toytec AAL's, Toytec poly rear leaf bushings, Deckplate Mod 4", 265/75r16 firestone destination a/t's
    im not sure about these trucks, but when we typically have an egr issue in nissans/infinitis here at work it ends up being a blockage or partial blockage somewhere in the egr system. it takes a wire brush and lots of brake clean to get all that garbage out.
  14. Apr 27, 2011 at 10:39 AM
    dustinclm
    Thibodaux, La
    thanks for the rep BTW
  15. Apr 27, 2011 at 5:01 PM
    zacharypaul89
    Zach
    Georgia
    2015 4WD DCSB
    Well, my check engine light came on today, so everything I did didn't work. I'm going to take off the EGR again and scrub with a wire brush and clean all the tubes out again and hopefully I'll have some results.
  16. Apr 27, 2011 at 6:07 PM
    brelandt
    Terry
    Dublin, CA
    yep, it can get tricky. The Civic HX I had cost me $412 for a new EGR valve. So taking your time cleaning it first is well worth the effort.
    Like I said each of my cars that needed it took a week of taking it back apart and cleaning it over and over until I got it all out. I even let the parts seat for 3 days in a bucket of gasoline and then carb cleaner and it didn't budge. Had to just bust it all out using coat hangers and anything around that was sharp and narrow that would get in there!
  17. Apr 27, 2011 at 9:40 PM
    dustinclm
    Thibodaux, La
    what code is your truck throwing? is the valve stuck open/close? mine was EGR excessive flow (stuck open) either way, apply vacuum to the top of the EGR and see if you can open and close the valve, then lube and clean more until it gets easier to open/close. then check your modulator - make sure air can flow through and check the little filter in there. my CEL kept coming back on between 20-150 miles after cleaning (which i tried 3 or 4 times) so i left it alone for a week or so and then it went off, so just give it time i guess.
    there are some good threads on here, give me sometime and i can find them.
  18. Apr 27, 2011 at 9:42 PM
    dustinclm
    Thibodaux, La
  19. Apr 27, 2011 at 10:01 PM
    brelandt
    Terry
    Dublin, CA
    mine was the opposite. No flow.
  20. Apr 28, 2011 at 6:24 AM
    dustinclm
    Thibodaux, La
    im no expert but there is probably a blockage somewhere. if u know the valve isnt stuck shut (it opens when u apply vacuum) take off all vacuum lines and make sure there is nothing in them, then check the tube from the exhaust manifold to the EGR for blockage, next check that the modulator is working. then lastly i would test the VSV valve for the EGR.
