still having sub trouble... PLEASE HELP =(
Discussion in 'Audio & Video' started by DSully72, Nov 20, 2010.
  1. Jan 10, 2011 at 8:44 PM
    #41
    xSpyderguyx
    xSpyderguyx Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    Faulty connection in your amp(such as connections, interior wiring, etc) or you are running your amp at an ohm level that it does not support.
    I can get you an answer if you answer these questions:
    Voice coils on your subs?
    Ohm rating on your subs?
    Power output on your amp?
    Ohm outputs on your amp?
    How did you wire your subs?
  2. Jan 10, 2011 at 8:50 PM
    #42
    DSully72
    DSully72 [OP] 2WD Problems
    Daniel
    Appling, GA
    04 PreRunner TRD Off Road
    voice coils: 4-layer
    sub ohm rating: 4 ohm
    amp power output: 1000w?
    amp ohm output: 2 ohms?
    Wired: bridged
  3. Jan 10, 2011 at 8:51 PM
    #43
    DSully72
    Daniel
    Appling, GA
    but should all this matter? i got my whole system to work off an ipod rather than my deck...
  4. Jan 10, 2011 at 8:52 PM
    #44
    xSpyderguyx
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    this is going to difficult over forums...
    Um...can you by chance send me the link to your subs and amp online?
  5. Jan 10, 2011 at 8:54 PM
    #45
    xSpyderguyx
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    oh alright. sorry about that, so you have heard your subs produce noticable bass???
    With your amp and your head unit?
  6. Jan 10, 2011 at 8:57 PM
    #46
    DSully72
    Daniel
    Appling, GA
  7. Jan 10, 2011 at 8:58 PM
    #47
    DSully72
    Daniel
    Appling, GA
    with my amp, yes, but with my head unit, no. HOWEVER, i heard bass coming from the subs in the other truck with that head unit.
  8. Jan 10, 2011 at 9:00 PM
    #48
    xSpyderguyx
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    Alright good good.
    How did you test your head unit out again? so you know your HU checks out?
  9. Jan 10, 2011 at 9:04 PM
    #49
    DSully72
    Daniel
    Appling, GA
    yeah my hu checks out as well. i ran rcas from the hu to the amp in my old frontier and got sound from the subs in the other truck. and i know from my rcas back to my subs my stuff is fine too cuz i put an ipod on the other end of the rcas going into my amp
  10. Jan 10, 2011 at 9:37 PM
    #50
    A7XT
    A7XT Reppin UWYO
    Kyle
    WYOMING
    '09 TRD Sport V6 Silver
    BRUTEFORCE FAB HYBRID BUMPER!, 1.5 AAL, 5100 at 2.5" in front, foglight and DRL mod, fully de-badged, diff-breather mod, aux backup lights, rear view switch on mod, full husky floor liners, yellow wire mod, black action packer toolbox, Rockford P3SD412 sub on a hifonics Zues, Pioneer 4200DVD, hitch recovery shackle, Toyota Ski racks over bed, 55W Bixenon 6000K, Rigid 4" LED bars on bumper, Black Ultra Thunder 17" rims
    Alright let me see if I have this straight...you get bass from the new subs and everything works fine in your taco when the RCAs are hooked up to either an ipod, or the headunit in your old truck. When you hook the RCA's from your new HU up to the amp in your old truck it plays music and bass. When you connect the RCA's to your new HU the sub doesnt do anything. The problem has to be the settings on your HU or amp. Try to match the settings from the HU and amp in your old truck to the ones in your taco and see if that works. If I am wrong and you have never heard bass from the new sub/amp combo in your taco, then there is a problem with the wiring of the subs.
  11. Jan 10, 2011 at 9:51 PM
    #51
    DSully72
    Daniel
    Appling, GA
    what settings could there be other than having them turned on and making sure im using the right preouts? theres some stuff using Hz that i know nothing about under xover settings, but would that keep any sound from coming out?
  12. Jan 10, 2011 at 9:55 PM
    #52
    liinxcore
    liinxcore Well-Known Member
    Jamil
    06 prerunner
    if the amp is getting consistent power it isnt the ground... hmm... how big is the amp? could be a general power issue. some subs want a certain amount of power and if you are only sending oh say 50w continuous then that would explain the lack of power and the sudden surge is just a bass clip? i guess i would have to hear the sound to know for sure. but i doubt it is your rca that owuld cause that
  13. Jan 10, 2011 at 10:00 PM
    #53
    DSully72
    Daniel
    Appling, GA
    my rca is fine. and belive me, there is no shortage of power. i have a 1000w mono going to a pair of 8" shallows (rms 200w). but even if that were the case, i wouldnt have heard the base like i heard it from the ipod. either some settings arent as they should be, or my deck just isnt compatible
  14. Jan 10, 2011 at 10:25 PM
    #54
    A7XT
    A7XT Reppin UWYO
    Kyle
    WYOMING
    I honestly have no idea man it seems like everything should work. The last thing you could try is to make sure that the xover setting on the amp is not filtering out the low frequencies. Maybe the amp is only sending high freqs that the sub cant play. That would be a cause for the humming (because the sub is not meant to play high freqs). WIsh I would help out more but it sounds like your headunit is kinda wierd
  15. Jan 11, 2011 at 4:38 PM
    #55
    DSully72
    Daniel
    Appling, GA
    okay a guy at work today told me to disconnect my illumination wire in the harness. he said its been known to cause problems like this. anyone ever heard of this? im not trying it until i feel it may work
  16. Jan 11, 2011 at 5:00 PM
    #56
    DSully72
    Daniel
    Appling, GA
    Bump please ^
  17. Jan 11, 2011 at 6:23 PM
    #57
    DSully72
    Daniel
    Appling, GA
  18. Jan 11, 2011 at 7:13 PM
    #58
    silvr07taco
    silvr07taco Well-Known Member
    SoCal
    07 prerunner Access Cab
    K&N air filter, Dual XDMA6415, Sound Ordnance™ M-1350, Infinity 1252w, Custom 12" sub box.
    i've never heard of this..
    Are you sure that out of the back of your head-unit you have your rcas connected to sub output?
    Are you connected with low pass filter enabled?
    If so then on your amp make sure its also set to low pass filter
    also your amp has input and output, your connected to input with your RCA right?
  19. Jan 12, 2011 at 4:30 PM
    #59
    DSully72
    Daniel
    Appling, GA
    Yes yes and yes. lol. like i said... i got some crazy stuff goin on...
  20. Jan 12, 2011 at 7:11 PM
    #60
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    I've seen a few threads talking about issues with the illumination wire after an install...found these after a quick search:
    http://www.tacomaworld.com/forum/audio-video/124842-new-stereo-works-until-i-turn-lights.html
    http://www.tacomaworld.com/forum/au...w-gauge-lights-go-out-when-headlights-go.html
    http://www.tacomaworld.com/forum/audio-video/131296-after-stereo-install-no-interior-lights.html
    Unfortunately, those threads seems to have different problems than you. I wonder if it's a setting in your radio that is the issue...
