Still shaking while breaking.
Discussion in 'Other Builds' started by FoundOffRoadDead, Mar 9, 2013.
  1. Mar 9, 2013 at 4:40 PM
    FoundOffRoadDead
    FoundOffRoadDead [OP] whiptastic handling
    Shamus
    Walnut
    Ford
    So i have a question for you brake guy's.
    On my ford i have done right and left rotors the works! All new parts every thing. bleeding the brakes and what not. All of the fittings on the trucks steering have been greased. But when i brake i have really really really!! bad shaking in the front end. To where i am scared to drive it. what do i need to do?
  2. Mar 9, 2013 at 4:42 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    It's really starting to make me mad
  3. Mar 9, 2013 at 4:43 PM
    Ming42083
    Ming42083 Member
    Adam
    Peoria, IL
    2012 reg cab 4x4
    brakes?
  4. Mar 9, 2013 at 4:45 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    Pads are not brand brand new, but they still had all the life left in them. They where done by the other owner about a week before i got the truck.
  5. Mar 9, 2013 at 4:45 PM
    jamtoz
    jamtoz frog
    James
    Quebec
    trd sport DCLB 4x4 2014
    Duratracs, SCS sr8's, debadged
    If you don't find slack in any of the steering linkages or bushings, then your brake caliper is shot.
  6. Mar 9, 2013 at 4:48 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    Figured. Just didn't want to think about it. Because nothing is loose on this truck. So that's the only other thing. :[ thanks!
  7. Mar 9, 2013 at 4:48 PM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    last pic, looks like all of the studs broke and tire came off... what happened, lets start there...
  8. Mar 9, 2013 at 4:50 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    Tire broke off the studs due to low air pressure in the tires and the tire hitting the spindle. Then in turn snapping the wheel off the studs.
    Could i grease the piston's on the caliper to see maybe if there just sticking?
  9. Mar 9, 2013 at 4:50 PM
    nj636
    Kev
    Jersey
    and what kind of rotors did you put on it
  10. Mar 9, 2013 at 4:52 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    Napa premium
  11. Mar 9, 2013 at 4:55 PM
    nj636
    Kev
    Jersey
    if the piston is hanging up you would smell the brakes burning and/or wheel would lock up. were the sliders on the calipers moving freely? even if they weren't, that wouldn't cause a vibration it would just cause the pads to wear unevenly. do you feel shaking in the steering wheel and/or does the brake pedal pulsate
  12. Mar 9, 2013 at 5:02 PM
    jamtoz
    jamtoz frog
    James
    Quebec
    If you grease the piston's use silicone based grease only, and some recommend using only brake fluid.
  13. Mar 9, 2013 at 5:03 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    Yes. it does move free. From left to right. Shaking in the steering yes. At time's the brake pedal does pulsate
  14. Mar 9, 2013 at 5:04 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    Greasing with break fluid? I do have silicone based grease.
  15. Mar 9, 2013 at 5:09 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    Should i just clean it all up and then see what happens? Cleaning rust and thing of that nature?
  16. Mar 9, 2013 at 5:15 PM
    jamtoz
    jamtoz frog
    James
    Quebec
    I rebuilt mine with only dipping the seals in fluid and wetting the pistons and cylinders in fluid too, ive done quite a bit of searching prior to this and here is a post i found on another forum;
    "I strongly suggest that VW brake rebuilding paste (or Rubber Grease) be used to lube the piston -- not brake fluid. Brake fluid is hygroscopic -- and it attracts atmospheric moisture. It will corrode areas of the caliper bore and piston, beyond the seal area. Note that so-called rubber grease is fully compatible with brake system rubber and with brake fluid. You can also get this product in most autoparts stores."
    Another one;
    "NO! NEVER USE BRAKE GREASE ON THE PISTONS", because it will, allegedly, contaminate your brake system.
  17. Mar 9, 2013 at 5:20 PM
    jamtoz
    jamtoz frog
    James
    Quebec
    Pads will 'wear in' to discs, if they're not quite right initially, they'll get a bit better.
  18. Mar 9, 2013 at 5:26 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    So do this for both sides and this should fix my break issue right?
  19. Mar 9, 2013 at 5:27 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    Figured that. Thank you so much for your help! TW Rocks!
  20. Mar 9, 2013 at 5:29 PM
    nj636
    Kev
    Jersey
    pulsating in the pedal tells me warped rotors. I have checked run out on new rotors (all different brands & qualities) & have found upwards of .010 of run out!
