Still shaking while breaking.
Discussion in 'Other Builds' started by FoundOffRoadDead, Mar 9, 2013.
  1. Mar 9, 2013 at 5:29 PM
    jamtoz
    jamtoz frog
    James
    Quebec
    trd sport DCLB 4x4 2014
    Duratracs, SCS sr8's, debadged
    :cheers:
  2. Mar 9, 2013 at 5:36 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    You seem to be brushing over a potential cause in that you busted your wheel off and looks like the original rotor took a very serious crash.
    You think that is related?
  3. Mar 9, 2013 at 5:42 PM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    if it bent the spindle he'd feel that while driving
  4. Mar 9, 2013 at 6:35 PM
    FoundOffRoadDead
    FoundOffRoadDead [OP] whiptastic handling
    Shamus
    Walnut
    Ford
    Truck still runs straight, so that tells me that along with no pull in the steering that its a brake issue. Thanks guys. I am going to have it all apart in the morning.
  5. Mar 9, 2013 at 6:51 PM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    If you've replaced the rotors, and pads, I would be thinking ball joints or bearings. A good way to test them is to jack up the front of the truck (by the frame) until the front wheels come off the ground. Then try to wiggle each tire in each direction by hand. If there is any play, then you've found the (or one of the) problem(s).
  6. Mar 10, 2013 at 6:30 PM
    nj636
    Kev
    Jersey
    so how'd you make out
  7. Mar 10, 2013 at 10:56 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    All new EVERY THING :] New calipers because the old one's where sticking :/ bolth right and left. But when i brake i still have shaking. [Tie rod's]? any one?
  8. Mar 10, 2013 at 11:04 PM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    wheel bearings man, i can almost gurantee your shitting a wheel bearing. jack up one front tire and from the top of your tire pull and push back and forth and if there is play i bet it is a bearing.
  9. Mar 10, 2013 at 11:06 PM
    ToyComa92
    Jon
    Conifer, Colorado
    just saw this post, I agree 2x try this man and i bet thats the problem its happened to me first hand.
  10. Mar 10, 2013 at 11:13 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    No wiggle all new.
  11. Mar 10, 2013 at 11:14 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    wheel bearings all new! :[
  12. Mar 10, 2013 at 11:19 PM
    ToyComa92
    Jon
    Conifer, Colorado
    huh wow man if its not a braking issue or a bearing issue then i dont know... have you had your alignment checked since replacing all these parts? its a long shot but who knows man im scratching my head just as much as you probably now that bearings is out of the question.
  13. Mar 10, 2013 at 11:28 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    I am past the point of scratching my head i am throwing wrenches now.
    I am thinking is a tie rod issue.
  14. Mar 10, 2013 at 11:29 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    Fun fact ford's calipers don't have an L or a R on them so i put them on upside down ass backwoods. :/ (yes backwoods)
  15. Mar 10, 2013 at 11:42 PM
    #35
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    I am really burnt out on this project.
  16. Mar 10, 2013 at 11:43 PM
    #36
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    My next truck is going to be at Toyota . . .
  17. Mar 11, 2013 at 3:00 AM
    #37
    nj636
    Kev
    Jersey
    did you change rotors again tho?
  18. Mar 11, 2013 at 4:28 AM
    #38
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    No need each side is true.
  19. Mar 11, 2013 at 6:07 AM
    #39
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    I do still need help :/
  20. Mar 11, 2013 at 6:09 AM
    #40
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    Rotor will make shake. Have you had them checked? I'd replace them if you haven't. Or get them 'turned'
