Still shaking while breaking.
Discussion in 'Other Builds' started by FoundOffRoadDead, Mar 9, 2013.
  1. Mar 11, 2013 at 6:13 AM
    #41
    FoundOffRoadDead
    FoundOffRoadDead [OP] whiptastic handling
    Shamus
    Walnut
    Ford
    Had them checked. I really don't think with both sides being able to spin freely they would be the problem, so my question is do i look into tire rods and new joints?
  2. Mar 11, 2013 at 6:19 AM
    #42
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    If it were tie rods or ball joints you should be able to wiggle them to see if the have play. Jack your truck up leave tire on and try and check play up down left right. Up down be ball joints left right will be tie rods or wheel bearings would have play every way,but u said them good. Have some one shake while you look under truck.
    Good luck!
    And if it not spinning freely the ball joints or tie rods have nothing to do with spinning. That's brakes or bearings.
    Edit. Also spin the tire when in air and listen for anything. Should spin quietly.
  3. Mar 11, 2013 at 6:26 AM
    #43
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    if they are new, make sure they are seated flat against the hub. there might be something keeping the rotors from being true against the hub. You can actually troubleshoot which side its coming from since it is 4x4. Turn off traction control put in 4x4 and jack up the whole right side or left side. Put it in gear and turn both left or right tires. Apply brake and see if it shakes.
  4. Mar 11, 2013 at 6:36 AM
    #44
    Millertime187
    David
    Clay City, KY
    1995 Taco
    :eek:
  5. Mar 11, 2013 at 6:48 AM
    #45
    Millertime187
    David
    Clay City, KY
    1995 Taco
    And I've somehow got this thread mixed with another.
  6. Mar 11, 2013 at 7:11 AM
    #46
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    How far did that thing slide down the road with no wheel? You probably bent the spindle you would not notice it driving but it sure would effect your braking mind you only a few thousands of an inch will cause it.
  7. Mar 11, 2013 at 8:32 AM
    #47
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    About 100 feet. Wouldn't i feel it while driving past 55 tho?
    I broke down, taking it to a job. :/
  8. Mar 11, 2013 at 8:35 AM
    #48
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    I will let you guy's know what the hell is going on. Making sure to update thank all of you for all your input.
  9. Mar 11, 2013 at 9:14 AM
    #49
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    I'm sure it's already been said, but just trade it in and get yourself a Taco. :thumbsup:
  10. Mar 11, 2013 at 10:16 AM
    #50
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    I am a ford guy :/
    So after all this. turns out it was the idle control arm. That well is not there, just a bracket with two welded bolt's putting it on there now, so just over looked it. But hey all new part's! :]
  11. Mar 11, 2013 at 10:23 AM
    #51
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Didn't read the whole thread, but that thing took a really hard hit. Every joint in the front suspension is suspect -- ball joints, tie rod ends, control arm bushings, shocks, etc. Tracking straight and braking are 2 different things, putting different loads on different parts.
    I wouldn't want this project either.
  12. Mar 11, 2013 at 10:27 AM
    #52
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    Well all joints are good, shop conferred this, and there's load's of play in the idle control arms. Due to it not even being there. Look's like who ever owned this did try to re enforce the front. But now where all good. Thank you guy's for all your help!
  13. Mar 12, 2013 at 1:48 PM
    #53
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    :facepalm:
    :facepalm:
  14. Mar 12, 2013 at 4:42 PM
    #54
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    I am on socalprerunner and desertrangers and rdc i like this site the most people really help and we all share common interests in truck and mod's trails and things of that nature, so what's the problem bud?
    Or am i not welcome here?
  15. Mar 12, 2013 at 4:59 PM
    #55
    nj636
    Kev
    Jersey
    yea really, check out the people on mustang world i'd say 1/3 don't even own a mustang lol
    you are more than welcome here!
  16. Mar 12, 2013 at 5:01 PM
    #56
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
