Stock 99' Tacoma: Need advice on lift/tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by mericanrebel, Dec 2, 2011.
  1. Dec 2, 2011 at 9:23 PM
    mericanrebel
    mericanrebel [OP] New Member
    SAN DIEGO
    99' Toyota Tacoma 2.7
    I just bought a 99' Tacoma regular cab & it's bone stock, I figured this would be the best place to ask for advice!
    1) How big of tires can I go without lifting it. (Would it look silly?)
    2) What would be the most viable means of lifting it, but not completely blowing all of my savings. (Which lift kit works best for my model)
    Thanks guys! :D
  2. Dec 2, 2011 at 9:28 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    i do believe you can put 31s stock. For a good affordable lift get the 3" eibachs with bilstien 5100 adjustable shocks. Alot of people also like the ome springs with the 5100s too. and as for the back that is up to you. New leafs are the best way to do it but you can get shackles or blocks which are alot cheaper. if it is just going to be your daily driver then just do that option.
  3. Dec 2, 2011 at 10:51 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner
    probly a spindle lift up front and block or flip kit out back would be easiest. 235/75 are a good start probly need regear if you go any bigger.
  4. Dec 2, 2011 at 11:15 PM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    Looks like a 5 lug.
  5. Dec 2, 2011 at 11:21 PM
    MadTaco461
    MadTaco461 BRO runner
    Murrieta, CA
    99 turbo 5 lug long travel
    Kinda stock
    ya mod that beast
  6. Dec 2, 2011 at 11:42 PM
    mericanrebel
    SAN DIEGO
    not sure how to tell if it's a 5 lug, but that's what I have been told from a friend.
    235/75 do you think it would look decent without a lift? I just want to be able to get off the beaten path without trying to race baja...
    however, if I can get a lift kit installed for less than 1200 then I am all for getting it lifted.
  7. Dec 3, 2011 at 5:17 AM
    pairodice
    Jay
    SF NM
    02 DCSB prerunner
    its a 5 lug, you can probly do the lift and tires for $1200. it will be about the same height as a stock 4x4 non trd with a lift
  8. Dec 3, 2011 at 7:45 AM
    MadTaco461
    Murrieta, CA
    Kinda stock
    You can throw some fabtech spindles in there. Gives you a 3" lift up front. New for 300ish or cheaper used. I saw a guy selling his for 180 obo. For 100 do an extended shackle. 15" black steelies run at $52 a pop. You can get some 31 10.50 15 tires and be rollin right around 1200. You could find also a cool tire wheel combo with that size. Hit up the SD BS thread if you are looking for someone to help you install the lift, but you can do it yourself with just normal tools.
  9. Dec 3, 2011 at 11:35 AM
    mericanrebel
    SAN DIEGO
  10. Dec 13, 2011 at 7:58 PM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    1. 215/75R15
    2. Doetsch 4" Lift Spindle 95.5”-04” Tacoma (5lug)
  11. Dec 13, 2011 at 8:13 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    ansars is red
  12. Dec 13, 2011 at 8:25 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    His only options up front are either spacers or spindles (spindles best option)...AAL or a shackle in the rear. 5 lugs dont have coilovers like the 6 lugs do.
    Should be able to run 30'' tires...maybe 31's if you do some trimming.
  13. Dec 13, 2011 at 8:55 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    oh ya, well dont i feel dumb, considering i had a 5lug....i never played with the front, so i forgot it wasnt a coilover. dont quote me on this, but i dont think 30s will fit at stock suspension.
  14. Dec 15, 2011 at 10:26 PM
    SRQ TACO
    Damon
    Sarasota, Florida
    Only on the 01-04 models but it will still rub over bumps. I had 29's on mine and they rubbed like crazy. And I have a coil spacer lift.
