Stock air box: can I put a smaller box on a bigger engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by BoneCollector, Aug 27, 2020.
  1. Aug 27, 2020 at 2:27 PM
    BoneCollector
    BoneCollector [OP] New Member
    97 Tacoma 4x4 3.4L
    My 1997 3.4L 5VZFE came with a K&N cone filter on it, but it's always throwing a P0171, so I want to go back to a stock air box. The MAF sensor is stock, so it seems like I should be able to just swap them out.
    I bought approximately this: https://www.ebay.com/itm/Air-Filter...-Tacoma-1995-2004-2-7L-3-4L-2-4L/312920685625
    But that air box is too small for the OEM panel filter that is supposed to fit the 5VZFE; I have the impression that the air box I bought is meant for the 4-cylinder engine. It's a 17700-0C020, while toyotapartsdeal.com makes it look like my engine needs a 17700-07041: : https://www.toyotapartsdeal.com/oem...&location=engine_fuel_tool/air_cleaner,,17700
    Does it actually make any difference if the air box isn't exactly the right size?
  2. Aug 27, 2020 at 2:29 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    '18 T4R & '94 FZJ80
    Triple locked and 35s
    I think you are fine as long as it will bolt up.
    Welcome to the forum!
  3. Aug 27, 2020 at 3:03 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You sure this will cure the PO171 ??
    The only thing might be if the air flow is not enough .
    to satisfy the MAF sensor.
    Do the 4Cylinders and 3.4 use the same MAF sensor
    To much of a problem to send this one back and get the correct one?
  4. Aug 27, 2020 at 5:05 PM
    BoneCollector
    97 Tacoma 4x4 3.4L
    Thanks for the warm welcome!
    I'm not sure about anything about the P0171 (cleaned the MAF sensor already), but I'd like the stock air box anyway, and I'm curious to see if it will help.
    It looks like 4cyl and 6cyl use different MAF sensors:
    https://www.toyotapartsdeal.com/oem...&location=engine_fuel_tool/air_cleaner,,22250
    https://www.toyotapartsdeal.com/oem/toyota~meter~assy~intake~air~flow~22250-20020.html
    I can't find any 17700-07041 online except the $400 OEM one, while there are lots of 17700-0C020 all over ebay.
    Then there's this guy: https://www.lowrangeoffroad.com/review/product/list/id/7897/category/128/
    Says 1999-2004 but might work anyway.
  5. Aug 27, 2020 at 5:43 PM
    jbrandt
    jbrandt Made you look
    Justin
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    According to the googles, common causes of that code are:
    • Dirty or faulty mass air flow sensor
    • Vacuum leaks – PCV hose, vacuum hoses, intake manifold gasket.
    • Weak fuel pump
    • Clogged or dirty fuel injectors
    • Exhaust leak
    • Faulty O2 sensor
    I'm not sure a new airbox would do anything.
  6. Aug 28, 2020 at 1:20 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    You can convert to the newer style MAF sensor I think it is only one wire in the plug that needs move
    I went with the newer air filter box after getting a truck with a cone filter because I had a extra one.
  7. Aug 28, 2020 at 3:38 AM
    Taco critter
    Taco critter #mall crawler , patw and ,ttc#0247
    Pottstown /stowe , pa
    02 tacoma 4x4 full mall crawler,
    Ome 3inch ,rims ,cold air intake ,,4 crawler body lift ,cb in ashtray mod,leds, jet maf,Satoshi grille,led roof bar,yakama roof basket ,smittybilt parts,spare tire mount in hitch ,rago fabrication parts, winch bumper ,winch ,285s on wagon wheels ,traction boards ,hi lift jack,wet oaklies,smittybilt ,bamf bedrack,loads more,TOO MUCH SHIT TO LIST
    Welcome to tw
    Black DOG Lila likes this.
  8. Aug 28, 2020 at 5:38 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
    Taco critter likes this.
  9. Aug 31, 2020 at 9:04 AM
    BoneCollector
    97 Tacoma 4x4 3.4L
    Update: the 17700-0C020 from ebay doesn't fit because it expects to bolt onto the MAF sensor housing, while my existing filter hose-clamps onto the MAF sensor housing. I looked around online for some sort of adapter but didn't find any. I might try that air box from lowrange.com next.
