stock battery voltage
Discussion in 'Audio & Video' started by zero niner, Sep 3, 2008.
  1. Sep 3, 2008 at 9:48 PM
    zero niner
    zero niner [OP] romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    Concerning car audio, what voltage can I expect my amp to see from a stock battery/alternator set up in a 2009 Tacoma Pre DC SB. Thanks in advance!
    Rob
  2. Sep 3, 2008 at 10:31 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    You should be fine what kind of setup are you looking at. on mine it reads 13-14 volts but i have an optima battery.
  3. Sep 4, 2008 at 4:46 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    That's great guys, thanks for the info, I ask because I'm looking at a Helix Amp that's rated 4x50 at 12 volts and 4x70 at 13.8 volts, so the amp will definitely react according to the voltage it receives. Thanks again for the info and confirmation!
    Rob
  4. Sep 4, 2008 at 6:36 PM
    MikeS.
    MikeS. Well-Known Member
    Far Eastern WVa
    2008 DC LB 4x4 in Speedway Blue.
    Undercover bed topper, Nerf style step bars, Python alarm, Ham radio with 250 watt amp and chrome wheel well bling.
    Your voltage from the battery will vary from motor on or off. The alternator output will also vary depending on battery charge. ^^ varies from 14.1 - 13.7 with the motor on.
  5. Sep 4, 2008 at 7:08 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    You sig says you have a bunch of stuff in a pod, would you mind posting a photo? Thanks.
    Rob
    (Nevermind, just browsed your photos, your truck is bad action!)
  6. Sep 5, 2008 at 8:50 AM
    billybobsgoat
    billybobsgoat Member of the Goat Army
    2020 TRD OR CCSB Graphite
    Where did you get this setup?? This is awesome.
  7. Sep 5, 2008 at 3:45 PM
    billybobsgoat
    Thanks
