Stock Gear Ratio 2010 w/ LSD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toyo freak, Oct 10, 2010.
  1. Oct 10, 2010 at 11:00 AM
    toyo freak
    toyo freak [OP] Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    What is it? I looked up my vin# and believe these are the numbers of concern: Atm-A04A/A750F
  2. Oct 10, 2010 at 11:02 AM
    The End
    The End Support our troops!
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    2.5 King RR in front, LR ucs' s, 2.0 King RR rear, B.A.M.F shock mounts, ATO shackle flip, 4X sliders, ARB front bumper with XRC8, CBI hc rear, weathertechs, Leer cap, Thule rack, ubolt flip, etc.
    4.10's.
  3. Oct 10, 2010 at 11:03 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    having a v6, your ratio is 3.73
  4. Oct 10, 2010 at 11:05 AM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    it is a v6 but I thought it was higher than 3.73, the truck has tow package, and all kinds of safety crap/traction controll
  5. Oct 10, 2010 at 11:06 AM
    jhodge83
    SC
    v6s are 3.73 and I4s are 4.10
  6. Oct 10, 2010 at 11:09 AM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    ok well damn I wish I had the 4.10, cause its better w/ 33s
  7. Oct 10, 2010 at 11:29 AM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Whoops, sorry. Brain fart.
  8. Oct 10, 2010 at 11:33 AM
    jhodge83
    SC
    depends on if you want acceleration or mpgs.
  9. Oct 10, 2010 at 11:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Running 4.10's with 33's would give better MPG, than running the same tires with 3.73's.....The engine isnt working as hard to spin them. When I went from 31's to 32's on my Dodge (4.7 V8), I regeared to 4.10's, and gained 2 mpg.....and MUCH better performance.
  10. Oct 10, 2010 at 11:54 AM
    jhodge83
    SC
    plugging 265/70/16 and 265/75/16 in the tire calc above shows better MPGs for 3.73s than 4.10s. tire weight has a lot to do w/ it though and so does skinny pedal. krookz's 33" MTs and wheels weighted ~110lbs and my 35" BFG ATs on 7089s was around ~89lbs and i was getting 18mpgs consistently.
  11. Oct 10, 2010 at 12:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And how was the Tire Clac. programmed to determin better MPG with tires? The lower gear ratio doesnt always yield the better MPG.
  12. Oct 10, 2010 at 12:12 PM
    jhodge83
    SC
    i would imagine that it is taking diameter and revolutions into account. still falls on the skinny pedal and knowing you wont take off the line as fast w/ a larger tire and lower ratio.
  13. Oct 10, 2010 at 12:34 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
  14. Oct 10, 2010 at 12:35 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    So 4.11 or higher has better acceleration right?
  15. Oct 10, 2010 at 12:38 PM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    The lower the ratio (numerically higher) the faster the acceleration but less top end.
  16. Oct 10, 2010 at 2:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Actually.....Top end isnt a factor as the truck is still limited in top speed regardless of what gears your running.
  17. Oct 10, 2010 at 4:35 PM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I'm just speaking gear ratios in general. But I know what you're saying.
  18. Oct 11, 2010 at 3:45 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Bump. What the hell is top end?
  19. Oct 11, 2010 at 4:22 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If your gears are sufficiently low, you'll hit top speed by readlining the engine in top gear and that fact, that you can't go any faster without over-reving will determine your top speed.
    However, most cars are either wind-limited in their top-end, or computer limited to allow for lower-speed rated tires to be fitted (they cost less) and more affordable insurance premiums.
