Stock Gears with Larger Tires
Discussion in '5 Lug' started by redman15, Apr 14, 2011.
  1. Apr 14, 2011 at 10:13 PM
    redman15
    redman15 [OP] Well-Known Member
    Randy
    Shannon, MS
    08 Tacoma 5 lug
    Any complaints on running 265/70R16's with stock gears?
  2. Apr 16, 2011 at 9:11 PM
    alexmxman185
    alexmxman185 Keepin' it dirty in Texas
    Alex
    Waco, Texas
    08 toyota tacoma 2.7 4 cly 5 lug
    Black grille guard with mounted kc road lights, 31x9.5x15 AT on stock rims. My future mod list: new white front bumper, Fat Bobs 2.75 spacer lift with rear AAL, american racing Flat Black Rims, 32x11.5x15 BFG A/T, satoshi grille with road lights mounted behind it, 8000k HID for all lights, 1'' Body Lift, new window tint, blacked out headlights and taillights, custom hood scoop, weather tech floor liners, LED dash cluster replacement, Front bilstein shocks, 40 series flowmaster, paint all my badges black.
    im running 31x10.5 and my first gear is super high even coming off of a dead stop and 5th is pretty much just for cruising on flat highway. As soon as i find a set of 3.73's or 4.10's it will for sure be worth the money to have it riding smooth again.
  3. Apr 16, 2011 at 9:32 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I agree with the above. I run 31x10.5x15 tires with stock gears as well. I've got some 4.10's, just haven't gotten them in yet.
  4. Apr 16, 2011 at 10:20 PM
    redman15
    Randy
    Shannon, MS
    08 Tacoma 5 lug
    Thanks fellas. No significant problem with running stock gears with 31" for a while?
  5. Apr 16, 2011 at 10:29 PM
    alexmxman185
    Alex
    Waco, Texas
    its just kind of annoying with 1st and 5th gear. But its tolerable.
  6. Apr 16, 2011 at 10:29 PM
    alexmxman185
    Alex
    Waco, Texas
    you would be a life saver if you still have the web link to those :D
  7. Apr 17, 2011 at 6:42 AM
    afd23a
    The Dynamo of Dixie
    hahaha no link, bought them on here about a year ago. Just haven't gotten them installed yet. Try calling east coast gear supply. They might have a r&p set around from a regear. Just make sure you tell them it's for the 8.4" and not the elocker.
    You can also watch the classifieds on another truck site. :anonymous:
  8. Apr 17, 2011 at 8:06 AM
    tig1
    tig1 Well-Known Member
    Paul
    Saint John,New Brunswick,Canada
    2009 tacoma
    n fabs,window visor tonneau ,bilstein 5100's all round.245/75R16Toyo A/T II
    I thought all tacoma's came with stock 4.10 gears.or is it just certain models.
    later tig1
  9. Apr 17, 2011 at 8:28 AM
    afd23a
    The Dynamo of Dixie
    In the 2nd gens the 4wd and prerunners with 4 cyl engines come with 4.10 gears. The v6 4wd and prerunners come with 3.73. The Xrunners have 3.15 I think. And the 5 lug trucks have 3.31 for manual tranny and 3.58 for the auto.
  10. Apr 17, 2011 at 10:46 PM
    Rconectn
    Rconectn Well-Known Member
    Miami, FL
    '10 Regular Cab
    When looking to re-gear is this what I'm searching for?
    T100/ TACOMA/ 8.4 4.10 GEARS - USED OE
    Good used T100, tacoma Non elocker, 8.4 ring and pinion 4.10 ratio. Used OE
    I plan to run 245/75R16 on my 5 lug would this be good enough to use? Also, is this the only component that I would need to re-gear or do I need additional parts? Sorry for the thread jack.
  11. Apr 18, 2011 at 8:53 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    swap it in and go! if you have auto, recommend 4.30s with 31s.
  12. Apr 18, 2011 at 9:32 AM
    alexmxman185
    Alex
    Waco, Texas
    4.30's?!?! I think 4.10 should be more than enough
  13. Apr 18, 2011 at 7:52 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I have 235/75/R15s with stock gears (3.58s with a 5-speed). It is a little slower but I can still chirp the tires so I'm happy.
  14. Apr 19, 2011 at 11:01 AM
    okspeed
    okspeed Active Member
    TX
    07 Taco
    Anyone know what the biggest tire size you can run with the stock gears and not notice a considerable difference?
  15. Apr 19, 2011 at 11:08 AM
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    my 98 4cyl 4x4 has 4.10s and thats stock from factory
  16. Apr 19, 2011 at 6:29 PM
    afd23a
    The Dynamo of Dixie
    The 2nd gen tacomas use what is referred to as the 8.4" differential. 4.10's are stock in the 2nd gen 4 cylinder 4wd and prerunner trucks. Check out the stock tire size for those trucks, it's 245/75/16. So by regearing to 4.10 you'll have the same ratio as a stock 4 cyl 4wd or prerunner. If you want to overgear then 4.56 is the most readily available ring and pinion ratio. It's up to you. If you want to run 33" tires then you might want to consider 4.56 gears. It's all depends on what you want to do with your truck.
  17. Apr 19, 2011 at 6:31 PM
    afd23a
    The Dynamo of Dixie
    I don't know too much about what ratios are used in the 1st gens.
  18. Apr 19, 2011 at 10:59 PM
    Rconectn
    Miami, FL
    '10 Regular Cab
    Thanks! I'll probably stick with the 30" tires, so I guess I will be using the 4.10 on my 5lug. So now I know that before I upgrade my tires I should already have the 4.10 ready to be installed once I go larger with my rims and tires. Thanks for the great info! From other post I've read from you I can tell you really know your stuff! Are you a mechanic? Thanks again
  19. Apr 20, 2011 at 6:34 AM
    afd23a
    The Dynamo of Dixie
    Thanks for the complement. I'm not a pro mechanic, I've just had the same questions as you and I like to work on my truck.
  20. Apr 27, 2011 at 10:38 AM
    Rconectn
    Miami, FL
    '10 Regular Cab
    What exactly is a 8.4" and a elocker and what are the differences?
