stock head unit with aftermarket subs question
Discussion in 'Audio & Video' started by Jamiedubs, Oct 7, 2014.
  1. Oct 7, 2014 at 8:44 PM
    Jamiedubs
    Jamiedubs [OP] Member
    San Diego CA
    14 Taco off road
    First: Yes I did search for this related topic and did not find anything. Found a few things close but not exactly.
    Second:
    I have a 2014 stock tacoma with touch screen dash unit (not navigation) I love the unit, blue tooth works great, and it syncs up perfectly with my phone so I don't really want to swap it out.
    I know how to wire the sub and amp, and speakers in the doors, question is about the head unit. I have been told by friends that there is a kit you can use to adapt your stock head unit to amp outputs with a remote wire. Has anyone done this? If so, did you find it easy to do? And did you have to tap into the steering wheel control wiring (I doubt it but just asking).
  2. Oct 8, 2014 at 5:49 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Intrested to find this out too.
  3. Oct 8, 2014 at 6:41 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I think what you are looking for is a LOC (line out connector). Taps into the speaker level outputs and provides an RCA and remote turn-on, along with some other tuning bits. I think one model is called CleanSweep. Might also post this in the Audio forum for input.
  4. Oct 8, 2014 at 7:04 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Correct! Or also called a really converter.
    Problem you might run into is trying to find the speaker wires behind the radio. Not really hard. Most of them are color matched.
  5. Oct 15, 2014 at 5:29 PM
    immski
    immski Well-Known Member
    Paul
    Omaha, NE
    SR5 4X4 4 Cyl
  6. Oct 16, 2014 at 4:32 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
  7. Oct 16, 2014 at 4:53 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Lots of info in the audio forum -
    To provide some basic guidance - As you turn up the volume on the stock head unit, the bass frequencies will automatically get reduced to nothing to prevent distorition and damage to the speakers. The stock head unit is tuned to operate only with the cheap stock speakers. That said, you cannot simply use cheap $10-$20 LOCs from the stock speaker level lines.
    Audiocontrol has some better LOCs that use frequency summation to flatten the source curve, however everyone that has one installed in the tacoma complains about pops and clicks and other noise.
    The only LOC that looks worthwhile at least to me is the JBL Cleansweep, which is about $300 - Cleansweep has an automatic calibration process you perform on install which flattens the source curve. A flat source curve is what you want to provide as input into your amps, otherwise you'll be missing certain frequencies from your music as you turn up the volume. At $300 however, you might want to start looking into aftermarket head units to achieve the same audio source quality.
  8. Oct 16, 2014 at 9:30 AM
    immski
    Paul
    Omaha, NE
    SR5 4X4 4 Cyl
    Ok. Thanks for the info. I may try the clean sweep. I really want the stock head unit. I am willing to try with this LOC first then see the results and later try the clean sweep. Thanks again.
  9. Oct 16, 2014 at 9:33 AM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Check out the link in my sig. I did the exact same thing but used a miniDSP instead of clean sweep.
  10. Oct 19, 2014 at 3:10 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Dont waste your time with hi low converter. See my post about adding subwoofer to jbl system. All you need is a "add-fuse" low profile mini fuse for your remote wire in #4 fuse spot and an amp that has hi level input like a fosgate. No rca are needed.
  11. Oct 19, 2014 at 3:13 PM
    Friedtacolover
    Travis
    Ontario, Ca
    Sold.
    I have an accubass loc2 for sale for 50$ notmally 80$ if anyone wants it. One of the best loc out there. I just used my high level inputs so never opened this.
  12. Oct 21, 2014 at 10:04 PM
    Jamiedubs
    San Diego CA
    14 Taco off road
    Thanks!
  13. Oct 21, 2014 at 10:36 PM
    012TacoDeAsada
    012TacoDeAsada Well-Known Member
    West Whittier
    2012 Tacoma MGM
    Icon all around,sick nicks fab front bumper..bfg a/t 275 80 17 on konig counter steer x,all pro rear bumper,5k hid,3k fog lights,rockford fosgate sound system on stock stereo,tints
    Also look into the Rockford fosgate 3sixty rbld.it's a converter that also gives you a remote out so you just plug into left and right high level outputs ..pretty easy..I used to run it before I got a sound processor..
  14. Oct 22, 2014 at 8:21 AM
    manethon
    manethon TTAS
    Toronto
    Many
    RF 360 bld is a nice unit
