stock height difference?
Discussion in '1st Gen. Tacomas (1995-2004)' started by apex9r, Oct 29, 2009.
  1. Oct 29, 2009 at 4:57 PM
    apex9r
    apex9r [OP] mountain rover
    '97 4x4 2.7 5spd
    starting from scratch
    I have a 97 lx 4x4 and want to know if all 4x4 taco's are the same stock height or if they differ in models. is it just a difference in tires?
  2. Oct 29, 2009 at 5:29 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    They should have come from the factory with all the same height. Why do you ask?
  3. Oct 29, 2009 at 6:27 PM
    apex9r
    '97 4x4 2.7 5spd
    well cause mine looks lower and I know it has to do with the steel wheels and no fender flares but im just wondering if 31's will make it sit as high as a stock TRD?
  4. Oct 30, 2009 at 7:08 AM
    machman
    machman Well-Known Member
    NE Alabama
    03 DC PreRunner TRD V6
    I would say yes to your question about 31's. That diameter is really close to the stock size of 265/70/16. Keep in mind that these trucks are kind of bad about the springs getting weak. This will make the truck sill a little lower.
  5. Oct 30, 2009 at 1:20 PM
    apex9r
    '97 4x4 2.7 5spd
    hmm ok thanks. have to look into the spring thing
  6. Oct 30, 2009 at 4:13 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    According to the 1997 factory specifications there are some slight differences in 4X4 overall heights.
    Regular Cab = 67.3" normally; 68.5" with optional wheels / tires
    XtraCab = 66.9" normally; 68.3" with optional wheels / tires
    Yes - the differences between 'normal' and 'optional' aren't the same for both models. No, I don't know why that is ...
