stock lenght lower control arms from total choas
Discussion in 'Suspension' started by tacoman68, Jul 14, 2009.
  1. Jul 14, 2009 at 6:04 PM
    tacoman68
    tacoman68 [OP] Well-Known Member
    Rio rancho nm
    4X4 08 Tacoma with ENGAGE long travel
    O8 Tacoma with Engage long travel front and rear 2.5/12 with resi and 2.0 bump stops up front with engine cage have bed cage with king 2.5/16 with resi and 61.5 deavers and 13in. Shackles with 2.0 bumps as for engine have douge thorny headers cold air intake and short shifter installed in tranny have racing seats with 4 point harness full alpine sound system
    has any one gotten any info about with new stock length lower arms from total choas? i want to know the wheel travel with the lower and upper control arms installed.
  2. Jul 15, 2009 at 7:26 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Well, correct me if I'm wrong, (it only makes sense).... if they're stock length, the wheel travel is going to be the same!
    Taken from the webpage at ChaosFab.com:
    Many customers do not want to install fiberglass fenders or increase the track width with a long travel system, but they crave the aftermarket performance benefits of increased dampening with dual shock capability and the added strength of the lower uniball conversion.
    Makes sense to me, they're just heavier duty.
  3. Jul 15, 2009 at 10:27 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    may get some slight travel from the uniball over the ball joint
  4. Jul 15, 2009 at 11:35 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    $1600 makes me grimace. Wish they were cheaper.
  5. Jul 15, 2009 at 11:13 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    sounds like just a more rugged set of arms with just an inch more travel over stock...
    at $1600, you are halfway to long travel and at least 30 to 40 percent more travel...
    if you got the money, then its a cool way to improve performance on a stock looking rig...
  6. Jul 16, 2009 at 8:34 AM
    The_Hodge
    SC
    i guess it wouldnt be too bad if u were trying to piece together an LT kit...but UCA's, LCA's, then the extended CO's and extended CV's if u need em
  7. Jul 17, 2009 at 8:22 AM
    tacoman68
    Rio rancho nm
    i just heard of them and wanted to know what you guys think thanks it sounds like it would just be better to go with the long travel after you buy the lower ones and the upper control arms.
  8. Jul 17, 2009 at 8:34 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Depends on how you use your truck and what your budget is. These will work with whatever coilovers you currently have while the long-travel requires longer coilovers. Also, the non-All Pro LT kits require fiberglass fenders.
    You're 4wd so you'll also need longer front axles, which will run you about $500-$600 plus labor to install them in your existing CVs.
    Lots to consider when going LT beyond the cost of the kit itself.
  9. Jul 17, 2009 at 5:12 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    I called TC about these when I first saw them a few weeks back and they told me absolutely no more travel than stock lca's. The two benefits are the option for a second shock and the lower uniball conversion. I have never heard of any issues with the stock lca's or the stock ball joints so these seem a little pricey for the main benefit being, having the option to run a second shock. If you need a second shock, you might as well go long travel. They do look nice though.........
