Stock ride height - a compilation
Discussion in 'Suspension' started by Caduceus, Jul 11, 2010.
  1. Jul 11, 2010 at 9:47 AM
    Caduceus
    Caduceus [OP] Well-Known Member
    the Lowcountry
    09 DCSB TRD 4x4
    Hey everyone
    A few times I've seen folks wonder what height their truck started at, since they forgot to check before a lift. I was at the dealer yesterday, so grabbed bumbers off 4 trucks they had. I used a regular tape measure, from ground to fender, using the center of the hub cap to keep the measuring point as close to similar as I could. Height is in inches (I'd have preferred millimeters for more accuracy, but only had an Imperial tape measure with me)
    Truck 1 and 2 were Prerunner TRD Sports. Truck 3 a Sport 4x4, and truck 4 a 4x4 (non off road or sport). All were in the lot, I assume none had the rear TSB performed.
    Driver Front; Pass. Front; Driver Rear; Pass Rear
    1) 34 5/8, 35, 37, 37 1/8
    2) 34 3/4, 34 7/8, 36 3/4, 37
    3) 34 3/4, 34 3/4, 36 5/8, 36 5/8
    4) 34 1/8, 34 1/2, 37, 37
    I lost my measurements, but on my truck (4x4 Sport) it was pretty similar- high 34-low 35 inches up front, I think low 37's in back. That was WITH the TSB rear leaf though.
    As you can see, even the trucks themselves have a lot of variation. I think it's safe to say that IF you didn't measure your truck first, you would probably be OK with a target height in mind and just going to that, instead of worrying that you may be a few tenths of an inch off.
    Hope this helps someone!
  2. Jul 11, 2010 at 9:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    What configuration were the trucks? 4 door? Ext. cab?
  3. Jul 11, 2010 at 2:28 PM
    Caduceus
    the Lowcountry
    09 DCSB TRD 4x4
    I think 3 were the DC SB, 1 was access cab. Can't remember which ones though! Either way, should all be the same chassis, right?
  4. Jul 11, 2010 at 2:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The weight varies a little bit, but its enough info for people to get an idea from.
  5. Jul 11, 2010 at 4:04 PM
    Caduceus
    the Lowcountry
    09 DCSB TRD 4x4
    I see someone didn't like the table format ;)
    Yeah, i realize the weight varies a bit between models, but then, it varies between prerunner and 4wd as well. I guess I should have paid more attention to that. Like you said though, it's a small sample, but a starting point.
  6. Jul 11, 2010 at 4:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I added punctuation.
