Stock Shocks noise?
Discussion in 'Suspension' started by Playz, Jun 19, 2008.
  1. Jun 19, 2008 at 11:25 PM
    Playz
    Playz [OP] Pepsi
    Whittier
    08 TRD Sport 4x4
    Flowmaster muffler, KandN intake
    My suspension in squeaking alot. Sounds like a old swing set. :mad: It's a 08 TRD Sport 4x4 with 13000 miles. Is this normal? I took it to the dealer and they said everything was fine. Where would I use WD40 or grease to try and fix this? I do go off roading and hit the trails pretty hard. Alot of water crossings. I'm guessing thats what caused it.
  2. Jun 20, 2008 at 5:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Water can make it squeek. See if you can have a buddy push down on the front, and in the bed, while you are under the truck. That way you can identify where the squeak is comming from. Then attack it as you see fit. :)
  3. Jun 20, 2008 at 5:44 PM
    Playz
    Playz [OP] Pepsi
    Whittier
    08 TRD Sport 4x4
    I can actually shake the truck from under and it seems like it is coming from the leaf springs
  4. Jun 20, 2008 at 6:15 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    the leafs probably need to be re-greased
  5. Jun 20, 2008 at 6:23 PM
    BlueTaco
    BlueTaco Well-Known Member
    Long Beach, CA
    08 Tacoma Speedwayblue
    I had the same problem. I cant hear it in the cab but when you get out or rock it you can hear it. Brought it to the dealership and they greased up the leaf spring. The problems still hasnt stopped. On the dealership worksheet they explained what they did but added "springs will likley need replaced". Whether they will or not is another story.
