Stock Single Cab 2WD options??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Acill, Oct 26, 2009.
  1. Oct 26, 2009 at 7:31 AM
    Acill
    Acill [OP] Well-Known Member
    Paul
    Port Hueneme, Ca.
    2017 TRD Offroad
    I've posted my trucks picture in my first post, but to refresh its a completly stock 05 single cab. No frills at all, small steel rims, no lift, manual 5 speed.
    I want to make it look a bit better, can i put a slight lift on it and go with a bit larger tire and rim set? I dont want to risk loading it down or making any problems pop up since its stock. I'm not looking for a super high truck, just something that more like a "truck" know what I mean?
    Any pictures of those that did something would be nice to see too.
  2. Oct 26, 2009 at 7:39 AM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    i have or well had the same set up the base model at first i wanted to lift it so the first thing i did was put some bigger tires and that made a big difference even with everything else stock and it gave me a little more clearence. i put on 30x9.5 which were fine no rubbing issues at all. but after that i went with a street haha.
    but also there is a ready lift which is about a 3 inch lift which would put you at a good height or i think you can run some billstein 1500's and a AAL in the rear. i think either way the biggest tire you can put on there is about a 32 with out haveing to cut anything.
    but hope that helps you out a little good luck man
  3. Oct 26, 2009 at 7:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    This is a five lug?
  4. Oct 26, 2009 at 7:54 AM
    Acill
    Paul
    Port Hueneme, Ca.
    2017 TRD Offroad
    I think its a 5 lug, need to pull the hub caps off to be 100% sure.
    So if I get a rim/tire set from another Tacoma that had larger ones it will work stock? I see a ton of nice rim sets with new tires for sale on craigs list here in San Diego all the time. I dont want a monster, just something a bit larger to improve the looks.
