Stock Skid Plate Bolt Size? 2nd Gen TRD OR
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ghardy, Oct 13, 2023.
  1. Oct 13, 2023 at 7:44 AM
    ghardy
    ghardy [OP] Well-Known Member
    Montana
    2013 Tacoma TRD Off-Road
    TRD Badged 5100 3rd Gen 2" Lift with ICON RTX Rear Leafs
    Long story short, I bought a 2013 TRD OR with tons of issues (fixed most now) and the vehicle was given to me with the stock skid plates but no hardware
    Anyone know the size of the skid plate bolts off the top of there head (or otherwise) so I can get the proper bolt to replace it??
    Thanks in advance..
    Looks like the 3rd gens are M8-1.25x20mm. hopefully it's something similar if not the same!
  2. Oct 13, 2023 at 7:59 AM
    ghardy
    Montana
    Island Cruiser likes this.
  3. Oct 13, 2023 at 1:27 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    If I remember correctly, the front plate bolts into brackets using the small bolts. The brackets bolt into the frame(or something like that) using the larger bolts.
  4. Oct 13, 2023 at 4:54 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    If you're buying the bolts, get grade 8. These have a habit of rusting in place then breaking when you try and take them out later. The grade 8 pretty much solve that problem.
    I actually swapped mine out for the harder version. I also put a dab of grease on them before installation.
  5. Oct 15, 2023 at 5:37 PM
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
  6. Oct 17, 2023 at 8:49 AM
    ghardy
    Montana
    Thanks for all the help guys! I have (x8) grade 8 bolts in there now. As described, there was a lot of existing corrosion in the open threads as the have sat without bolts for likely more than a year..
    winkel likes this.
