Stock Spare Tire on Lifted Truck??? -- Lots of Questions
Discussion in '5 Lug' started by Early B., Jun 3, 2017.
  1. Jun 3, 2017 at 3:22 PM
    Early B.
    Early B. [OP] Well-Known Member
    Brad
    metro Atlanta
    2014 2.7L, 5 lug Tacoma
    18" tires and rims, 2.75" Procomp lift, Fox shocks in rear.
    As soon as I purchased my 5 lug, I bought 18" wheels and rims, then did a 3" lift. Several months have passed and the thought of the spare tire hadn't crossed my mind until today. First question is...
    1. Will the stock tire still work in my case?
    2. If not, should I replace it with an 18" steel rim and "small" wheel?"
    2A. If so, will an 18" rim and wheel fit in the spare tire well?
    2B. Will this rim work? https://www.amazon.com/5x114-3-fini...rd_wg=kHC5N&psc=1&refRID=PTJZVW8ARPYZSK949H3H
    3. What other options should I consider?
    Thanks.
  2. Jun 3, 2017 at 3:29 PM
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
  3. Jun 3, 2017 at 6:30 PM
    SamGoingHam
    SamGoingHam IG: SamGoingHam
    Sam
    Phoenix, Arizona
    2014 TACO 5LUG LOCKED
    If you were to get a flat, you're still able to use the spare. I had to do it once when I got a flat off-roading. Make sure the offsized tire isn't in the back with the solid axle or you're gonna fuck shit up. You'll have to swap a front tire to the back if you get what I'm saying.
    Learned my lesson after that, just get a proper size spare that is/close to being the same size.
  4. Jun 3, 2017 at 6:32 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  5. Jun 18, 2017 at 1:14 PM
    Early B.
    Brad
    metro Atlanta
    Update -- I purchased a new 18" steel rim and bought a used tire (265/60/18) for it. Size is 31.5" and it barely fit underneath the truck. Altogether it cost me $165. Provides some peace of mind to know that I have a spare the same size as my tires.
    HackD and 02YotaGuy like this.
