Stock Sport Wheels on a 1st Gen.?
Discussion in 'Wheels & Tires' started by Bolt79, Jul 24, 2011.
  1. Jul 24, 2011 at 2:15 AM
    Bolt79
    Bolt79 [OP] Well-Known Member
    White Springs, FL
    2011 Tacoma Sport 4X4
    265-70-17 Goodyear Duratracs. Pro Comp 17x8 8089's. Bilstein 5100's front and rear (front set to 1.75). 1/4 inch spacer--driver side. TSB rear leaf springs. WeatherTech floor liners. EGR in-channel vent visors. RDS tool box.
    Does anyone know if stock 17' sport wheels will work on a 1st generation Toyota Pre-runner? Thanks--don't have time to do a search this morning, got to get to work.
  2. Jul 24, 2011 at 9:19 AM
    glorie yota
    glorie yota Active Member
    Nichole
    Colorado Springs, CO
    02 Tacoma 3.4L V6 TRD 4WD 5spM K&N intake
    K&N Cool-Air Intake *just getting started*
    I believe it depends on how wide they are. I know most are 17x9 - which simply, is too wide.
  3. Jul 24, 2011 at 11:08 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The TRD sport rims are 17x7.5".
    And why is a 9" rim "simply too wide"?
  4. Jul 24, 2011 at 11:25 AM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Yes they fit, but the problem is you cant run a wide tire becuase it will rub on the Upper arm.
  5. Jul 24, 2011 at 12:27 PM
    Bolt79
    White Springs, FL
    Will a 265/65/17 work, or is that too wide?
  6. Jul 24, 2011 at 1:27 PM
    Anthony250
    Anthony
    San Gabriel Ca
    That might rub, thats the size i wanted to run but i asked around and heard it will rub, 255/75/17 is the biggest, since the wheels have 5.5 back space 12+ offset,
    but then agian they dont make much tires in that size, you can run 265 with wheel spacers 1" at the minimum
  7. Jul 24, 2011 at 1:56 PM
    Bolt79
    White Springs, FL
    Thanks, Anthony. I've got a friend that wants to buy my sport wheels with the stock Bridgestones and we're trying to figure out if they'll work.
  8. Jul 24, 2011 at 1:58 PM
    KPT
    09 Prerunner
    TRD sport wheels have +32mm offset, not +12.
    +32 is 5.5" backspacing on a 7.5" wide wheel.
  9. Jul 24, 2011 at 2:16 PM
    Anthony250
    Anthony
    San Gabriel Ca
    oops , well look at that its alot more than 12 anyways ,
