StopTech Rear Brake Hose Fit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pgm944, Nov 19, 2019.
  1. Nov 19, 2019 at 7:54 AM
    pgm944
    pgm944 [OP] Active Member
    SE Massachusetts
    2009 Tacoma Access I4
    2009 Tacoma Access Base 4WD 5-Spd Manual 2.7L
    I bought StopTech stainless steel braided hoses:
    Rear Stainless Steel Brake Lines Stop Tech Part No. 950.44520
    My mechanic says they do not fit through the holes which retain the hose as the wheel moves up/down.
    Has anyone installed these and run into this problem? If so, what did you do about it?
    TIA
  2. Nov 19, 2019 at 12:33 PM
    pgm944
    SE Massachusetts
    Wow - Thank you! :bowdown:
    In the back of my mind,
    why would the **brilliant** Toyota (Toyoda-inspired) engineers would do this?
    From a DFMA (design for manufacturability and assembly) and the Toyota's TPM viewpoint (of which I promote both with my clients I consult with), I am speechless.
    ugh. :confused:
  3. Nov 19, 2019 at 12:40 PM
    pgm944
    SE Massachusetts
  4. Nov 19, 2019 at 5:18 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    2009 and my Goodrich rear braided hoses had the same problem and yes I filed the bracket to allow the hoses metal crimped flat sides to fit so it is fixed in the bracket otherwise you can't properly connect to the metal brake line. A Dremel would be better and I bought one after that filing job. Its a leaking mess with the old line off so get a piece of rubber hose to push over it and a container to catch the brake fluid. Fronts fit perfectly so when I did the rears I was not expecting the misfit.
