Strange button
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Barhopper, Mar 24, 2019.
  1. Mar 24, 2019 at 8:01 PM
    spazjensen
    spazjensen Well-Known Member
    Here
    06 Tacoma Prerunner SR5 4cyl 5spd Manual
    3" lift with Biltein 5100's and Eibach Coils
    Saw this on ole buddy's 94 4runner. Had it stolen twice and he put a second ignition switch that he would have to click on with his foot before turning the key. Worked well unless his foot accidentally turned it off while driving :D:eek::annoyed:
  2. Mar 24, 2019 at 8:02 PM
    spazjensen
    Here
    I'm good like that dontchaknow lol
    PzTank and Barhopper [OP] like this.
  3. Mar 24, 2019 at 8:05 PM
    Barhopper
    Barhopper [OP] Well-Known Member
    Dustin
    Nw Georgia
    2010 Tacoma Sr5 Double Cab Long Bed
    King coil overs 2.5 with #650 springs, Spc UCA, OME Dakar standard leaf pack, extended Bilstein 5100, Pelfreybilt aluminum front and Pelfreybilt steel rear bumper.
    On a side note the vsc mod worked out pretty damn good I thought.
  4. Mar 25, 2019 at 1:25 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Mabey a back up camera momentary switch?
  5. Mar 25, 2019 at 6:12 AM
    jmanscotch
    jmanscotch Texan
    Jake
    Colorado Springs
    Lexus GX460
    If you want to disable the beep:
    1: Open the drivers door, take a seat, leaving the door open. Insert the key into the ignition.
    2: Fully remove the key from the ignition and, within 5 seconds,
    reinsert the key back into the ignition and switch to the ON position (not ACC, not RUN).
    3: After 10 seconds, the system enters the 'answer-back mode' indicated by a beep from the dash.
    4: Within 10 seconds of beep, press either unlock/lock (just pick one, then use it for both presses) on the remote, twice. The system will turn off
    or on, or whatever the opposite setting is that it's currently on. Odometer display should read 'bp on' or 'bp off' I believe.
    5: Turn key off and remove it. Get out of truck, shut door and test function.
    Some tips to keep in mind if it doesn't work:
    • The driver side door is closed.
    • The ignition switch is turned off.
    • The key is removed from the ignition cylinder.
    • A transmitter button is not pressed for 10 seconds after answer-back switching mode is started.
    • The transmitter is operated but the second button pressed is different from the first.
    • Answer-back starts.
    If you want to keep the beep, but tone it down a notch:
    1: Buy/find a pair of foam in-ear plugs.
    2: Open the hood and take a look in front of the battery on the drivers side. Locate the little black box with a hole that faces towards the battery. To be sure of the box location, press your remote (Caution: will be LOUD).
    3: Take one foam earplug and roll it small, insert in small hole, allow it to expand.
    4: Enjoy muted beep, but lack of silence.
    This was my initial thought. Unfortunately, there's lots of mods that wire into the drivers side kick panel area so it's hard to know for sure.
    Marc70 likes this.
  6. Mar 25, 2019 at 6:13 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    remote start programming button
  7. Mar 25, 2019 at 3:30 PM
    Barhopper
    Dustin
    Nw Georgia
    Will definitely try this
  8. Mar 25, 2019 at 3:31 PM
    Barhopper
    Dustin
    Nw Georgia
    Man I wish it was. Any idea how to check that
  9. Mar 25, 2019 at 7:55 PM
    Blais03
    Nick
    Easthampton MA
    Honestly no. But my truck has a remote start and button that looks identical. The guy who put it in says it’s for programming
  10. Mar 25, 2019 at 10:37 PM
    MtnBorn
    MtnBorn Member
    07 Toyota Tacoma DCSB TRD Sport
    I just found one of those same buttons under my drivers side panel as well. There is an aftermarket remote start installed so I’m guessing that’s what it’s for! Glad I read this thread. Now I can sleep tonight.
  11. Mar 25, 2019 at 11:28 PM
    N2DesignsInc
    N2DesignsInc ----------Owner---------- N2 Designs, Inc. Vendor
    Jimmy
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Sometimes those are 3X lock after market remote start valet/kill switch.
    have you tried pressing lock 3 times to check if you can remote start?
    The remote starts I sell for HKEY have the same button. They are used to kill the remote start and to program the smart phone app control module. With mine, if you press it 3 times, it takes it out of valet/kill mode.
    To enter valet mode you turn the ignition on (2 clicks of the key, or two presses of the push to start) and press the valet switch 3 times. Again, same thing to exit valet mode.
    Try that.
  12. Mar 26, 2019 at 10:16 AM
    Barhopper
    Dustin
    Nw Georgia
    Cool I’ll give that a try
  13. Mar 26, 2019 at 10:41 AM
    Gunshot-6A
    Gunshot-6A Not a Fed
    Conner
    Salt Lake City
    2015 TRD Offroad
    Obligatory F&F pic:
  14. Mar 26, 2019 at 10:47 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2016 RAM 1500 EcoDiesel
    remove the noisemaker, in the engine bay, near battery, looks kind of like a blue mailbox, but not blue, its black.
    first gen thread, but it looks the same. I came across mine in my toolbox over the weekend in the garage. Tacoma's been gone for a year now :anonymous:
    https://www.tacomaworld.com/threads...ff-on-the-unlock-command.155100/#post-3157383
  15. Mar 26, 2019 at 3:34 PM
    #35
    whipper
    whipper Well-Known Member
    2007 PreRunner
    Do you have a DVD player?
    if so, if you push the button while driving it will enable you to watch the DVD. Parking break simulator.
    :confused::confused::confused:
  16. Mar 26, 2019 at 3:35 PM
    #36
    FishnTx
    FishnTx rather be feeeschin
    Texas
    ‘17 OR
  17. Mar 26, 2019 at 9:46 PM
    #37
    tn510
    tn510 Well-Known Member
    Have the button on my 06 tacoma dcsb or. Not to sure what it does also.
  18. Mar 21, 2020 at 6:06 PM
    #38
    BenevolentMachination
    BenevolentMachination Well-Known Member
    Ground Zero
    2000 Tacoma 3RZ 4WD Xtra
    Time to revive an old thread!
    I bought my truck two years ago; I've never experienced any alarm feature as it was deactivated.
    However, after I wrecked my truck and had the battery removed for repairs; I realized the extra horn was for an aftermarket alarm.
    I say aftermarket, because I too, have that small button attached to the lower cigarette lighter panel on the driver's side of the center console.
    When I bought the truck, I was not given a key fob and there were no beeps when I interacted with the vehicle in any way that would indicate there to be an alarm present.
    My question: How do I disable the alarm (perhaps using this button?) without a key fob? As now every time I hookup the battery and have the door open; the alarm sounds.
    Edit: I found the answer to my question by searching: https://www.tacomaworld.com/threads/how-to-disable-alarm-on-2001-toyota-tacoma.525092/#post-16726002
