strange clunking sound from front end
Discussion in 'Technical Chat' started by tsmith, Oct 25, 2008.
  1. Oct 25, 2008 at 11:45 AM
    tsmith
    tsmith [OP] New Member
    new england
    07 tacoma v6 trd
    i have an 07 that is making a loud clunk or pop evey time i step on the brake moving in the opposite direction i have jacked up the truck and rotated each tire independantly and both sides are making the same noise when moving the tire in opposite directions i don't believe it is the brakes any info would help
  2. Oct 25, 2008 at 1:16 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    steering stop? grease it up maybe....
  3. Oct 25, 2008 at 1:36 PM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    I hear it too on my 05 PreRunner TRD Off Road when going in reverse.
    But then a coworker who has a 98 Camry says that his car does the same thing (make a clunking noise) when going in reverse.
    Probably normal.
  4. Oct 25, 2008 at 4:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The brakes on the front have "floating" calipers. Its normal for there to be a "pop" or "Click" when backing and applying the brakes. :)
  5. Oct 25, 2008 at 5:14 PM
    bambooshoots
    Kevin
    College Station, TX
    Actually mine comes from the back end...reading compreshension is important!
  6. Oct 25, 2008 at 5:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Meh, I make the same mistakes often. :eek:
  7. Oct 26, 2008 at 4:54 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I think they're non-floating calipers. There are pistons on both sides (2005+ years).
  8. Oct 26, 2008 at 6:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You are correct that they are not a floating caliper. My buddy is wrong, and a dork. I know better.
    All the Tacomas (1995.5 and up) and many Toyota truks a few years older have pistons on both sides (4 piston) But there is some play in the units. I was told they were called "floating calipers", though thats not the case.
    The noise is caused by the pads moveing. Most of the time your brakeing from forward directon, and the pads are resting on the forward most part of their pins. When you back up, and hit the brakes, they move to the rearward most part of their mounting causeing the "Clicking". Many Toyota cars and trucks do the same thing.
  9. Mar 28, 2009 at 12:56 PM
    canuck_tacoma
    canuck_tacoma Well-Known Member
    BC, Canada
    SR5 4X4 Tacoma Access Cab
    1.5" Eibach Front Coil Lift, Rear TSB, 265/75/16 BFG A/T's
    Anyone found a fix for this?? My brakes are quite noisy when I back up and hit them. I assumed it was the pads slidding to the back of the caliper. Never hear it untill I back up so it isn't too bad but it is annoying.
  10. Mar 28, 2009 at 2:30 PM
    bambooshoots
    Kevin
    College Station, TX
    So it's pretty much normal, correct?
  11. Mar 28, 2009 at 3:05 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Mine do the same thing in the front (2002). Was told by Toyota mechanic it's normal, pads moving back and forth in the calipers. Just find it odd it doesn't do it ALL the time.
  12. Mar 28, 2009 at 3:28 PM
    canuck_tacoma
    BC, Canada
    I crawled under the truck to make sure all the pins and springs were in place on the calipers. Looks like everythingi s where it should be. I can grap the pads and move them back and forth in the caliper and re-create the noise.
    I am not going to worry too much about it as I now know that there isn't anything seriously wrong with them. Just irritating.
