Strange electrical noise from underneath the truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MetrickMetal, Feb 27, 2017.
  1. Feb 27, 2017 at 2:39 PM
    MetrickMetal
    MetrickMetal [OP] Praise the Lowered
    Scott
    Yerington NV
    2017 Super White SR5 Access Cab / 4WD, AT / TP
    See my sig for mods
    For about 3 months now I will go out into the garage where my 2017 SR5 is parked and I hear a high frequency electrical buzzing / hum sound, and it’s happened about 6 times counting today.
    The sound is definitely coming from underneath the truck, and between the back of the cab and rear differential. I found out after the first time it happened that turning the ignition on / off stops the buzzing.
    So, next time it happens I’m going to crawl underneath the truck and see if I can locate the source of the noise. It’s loud enough that I can hear it from 6 to 8 ft. away, and it’s very strange as the truck had been parked for over 5 hours today when I heard the noise again. I had been in and out of the garage earlier this morning after it had been parked for well over 2 hours and there was no noise coming from the truck.
    So again I turned the ignition on / off and the noise stopped.
  2. Feb 27, 2017 at 2:45 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    It says in the manual it's an evap test. Also 90 other threads with the same question.
    Kev250R, DAS Taco, a400ryan and 8 others like this.
  3. Feb 27, 2017 at 2:46 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    could it be the outside air vent opening?
    If you have carista or TIS there's some option in it that after the vehicle is shut off a vent opens to let air in.
  4. Feb 27, 2017 at 2:46 PM
    Joe23
    or that...lol
    haven't heard of this evap test one but I know I've heard the vent thing.
  5. Feb 27, 2017 at 5:19 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    yea, very spooky.....i will go into my garage a like 10pm, truck has been off for many hours and the evap test is running. what the hell does this truck just sit there and think of things to do on its own.
    Tacoma3rdGen and Spare Parts like this.
  6. Feb 27, 2017 at 6:12 PM
    TRDinOhio
    TRDinOhio Well-Known Member
    Andrew
    Lima
    16 Trd Pro 4Runner
    No more Turd-gen :)
    Good old EPA mandations...
    Your truck tests the integrity of the fuel tank/low pressure system for fuel leaks or fuel vapor leaks. Most cars are required to do this now. Most cars use a small pump and pressurize or vacuum the tank down watch for pressure drops OR the amperage of the pump that's required to maintain a set pressure or vacuum.
    2016Tacoman likes this.
  7. Feb 27, 2017 at 10:04 PM
    DarkSky
    DarkSky Well-Known Member
    Oregon
    2016 SR5 Double Cab V6 Auto 4X4 Barcelona Red
    Yes it's the evap test. It automatically comes on something like 4 hours after the engine is shut off. It's explained in the manual. Both my Tacoma and my Lexus RX350 makes this noise. It really baffled me the first time I heard in on the Lexus.
    shakerhood likes this.
  8. Feb 28, 2017 at 5:22 AM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    Thanks for the replies, and like I said the noise is coming from underneath the truck, and right in the area of the gas tank. I scoured both the owners and service manuals and did not find any explanation about this EVAP system test. So can anyone tell me where this test is explained in the owners manual.
  9. Feb 28, 2017 at 5:43 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    shakerhood, tcjacado, kman66 and 2 others like this.
  10. Feb 28, 2017 at 5:49 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Perfectly normal. My wife's new RAV4 does it too. Freaked me out the first few times too.
  11. Feb 28, 2017 at 6:14 AM
    wjrichardson
    wjrichardson Well-Known Member
    WI
    2017 TRD/OR/AC
  12. Feb 28, 2017 at 6:33 AM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    I'm glad to find out it's nothing wrong with the truck.
    :amen:
  13. Feb 28, 2017 at 6:38 AM
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    My tacoma and scion do it.
  14. Nov 5, 2017 at 7:04 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Ugh- that would scare me too- in the olden carburetorated car days with my first car, I had a old BMW with an electric fuel pump that decided to stay on one day when I was away. The fuel pump continued to pump fuel and the float valve didn’t stop it, so it filled up the carburetor and ran down into the cylinders, eventually flooding into the oil pan and eventually leaking out of the engine onto the ground. When I came home, my mom told me that there was a leak under my car. I went out to look, and saw a big puddle of oily gasoline heading towards the gas pool heater which had a pilot light! Yup, hearing a fuel pump running on a parked car would scare me too.
  15. Nov 20, 2018 at 8:34 PM
    DarthNaderton
    DarthNaderton New Member
    2018 Toyota Tacoma SR5
    I found this on page 8 of my 2018 Tacoma’s owner’s manual:
    “Approximately five hours after the engine is turned off, you may hear sound coming from under the vehicle for several minutes. This is the sound of a fuel evaporation leakage check and it does not indicate a malfunction.”
    Could this be the answer?
    Edit: Just saw this same answer has already been posted. Never mind. Late to the game here.
  16. Nov 20, 2018 at 8:50 PM
    Scotty Dosent Know
    Scotty Dosent Know Well-Known Member
    2017 Tacoma DCSB
    Glad you posted this as my wife came in last night telling me that the truck was sitting in the driveway making a strange noise. Crawled under there with a flashlight and found where the noise was coming from..........glad I now know LOL
  17. Nov 21, 2018 at 9:19 AM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    discovered that on my 16 a few months in. the unsettling part is that it is doing test or whatever it is while it is off, let alone the fuel system. when i discovered mine i was in the garage at 11PM, not comfortable with that in the middle of the night in my garage while i am sleeping.
  18. Nov 21, 2018 at 9:21 AM
    Teegs
    Teegs Well-Known Member
    Finally an answer to this. Honestly, its pretty annoying when you're trying to sleep in the bed out in the woods.
  19. Nov 21, 2018 at 9:28 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    love this post heard that sound in my garage one day .Freaked me out thought it was something electrical in the walls of my house lol
  20. Nov 21, 2018 at 9:35 AM
    ICU1
    ICU1 Well-Known Member
    Russian listening device.
    tcjacado likes this.
