Strange Front Seat / Seatbelt Scenario Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IrishPilot, Dec 15, 2009.
  1. Dec 15, 2009 at 8:45 AM
    IrishPilot
    IrishPilot [OP] Well-Known Member
    MN
    09 TRD Off-Road 4x4 Double Cab
    In the last week or so, Ive had an issue with the front passenger seat and the the seatbelt alerts. If someone occupies the seat, and then exits the truck while its still running (i.e. I drop someone off somewhere) the seat seems to believe its still occupied and I get the seatbelt chimes and flashing alert.
    I do have Wet Okoles installed, however I dont know how that would necessarily change the system. Any insight from a guru would be greatly appreciated!
  2. Dec 15, 2009 at 1:09 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    You have weight/load sensors in the seat, looks like your seat covers are on too tight (common prob) and pressing the cushion down on the sensor making it think someone is sitting in the seat.
  3. Dec 15, 2009 at 1:47 PM
    IrishPilot
    MN
    I thought that...but I dont have the problem any other time (empty, gym bag, etc.) Its only when a body occupies the seat and then gets out. Really doesnt seem like the WO's would change that at all...but I could be, and probably am wrong.
  4. Dec 15, 2009 at 1:57 PM
    Asgard
    ^^ There are two sensors, one in the seat and one in the back support. I suspect it is the one in the back support that is causing the problem. I would take the WO's off the front passenger seat and see what happens.
  5. Dec 15, 2009 at 2:10 PM
    AzPrerunner05
    AzPrerunner05 Desert Rat
    Tucson
    2005 V-6 SR5 PreRunner Debadged
    De Badged, Flowmaster 50 Muffler & Dual Out Exhaust. K & N High Flow Filter. SP Racing Slotted Rotors
    Don't you have a key to turn off the passenger air bag? That should cut the seatbelt noise right? Happy I bought an 2005, it never tells me to put my belt on.
  6. Dec 15, 2009 at 2:23 PM
    Asgard
    DCs don't have that feature, I guess it's because we have a full size back seat (for the child seat).
  7. Dec 15, 2009 at 2:33 PM
    AzPrerunner05
    Tucson
    Ahh, there's the problem. You have a double cab ;)
  8. Dec 15, 2009 at 5:17 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    before you take the WOs off try this. put soemthing with some weight to it in the seat and buckle it in. drive a sec and have soemone open the door and remove it. see what happens. shouldn't take a lot of weight to get the truck to think its a person.
    regardless you could do the seatbelt chime shutoff. here it is.
    1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
    2) Make sure seat belt is not fastened
    3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
  9. Dec 16, 2009 at 1:47 PM
    AzPrerunner05
    Tucson
    Fucking awesome !!:eek:
    This work on Carolla and Prius?
  10. Dec 16, 2009 at 2:02 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt. Does this work on a 07 ?
  11. Dec 16, 2009 at 2:37 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I had the problem with a cab commander that hangs off the head rest and only touches the seat back.
    I must have had too much stuff in it.
