Strange humming coming from rear end.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma420, Nov 19, 2011.
  1. Nov 19, 2011 at 11:46 AM
    Tacoma420
    Tacoma420 [OP] Well-Known Member
    Forrest
    Placerville CA
    17 4x4 Tacoma Off Road
    Alright, Well for 1, im new to the forums. Figured fellow tacoma owners may know my problem.
    I own a 99 prerunner with 195k on it, ive had it sense it had 60k.
    Ive went thro having my CAT stolen, to having my vehicle broken into.
    When my Cat got stolen, at least my insurance took care of it and did the exhaust from the manifold back to the tailpipe, but anyways its not about that.
    I have this humming coming from the rear end, when im going around 40+ and when im barely on the throttle it makes the noise.
    If i let off the gas, then it stops making the noise completely. If its making the noise and i give it some more gas, then it goes right away.
    It appears to happen when im going uphill or a flat the most, and when its about 2k rpm.
    Its an automatic btw too.
    I went and got the U-joints replaced, thinking it would be a simple fix, and i had no luck there.
    I just need to see if any other tacoma owners had this problem, or if i should just bring it into toyota to get it checked out.
    Only been happening for about 10k miles. And seems to of started happening more lately.
    Its not a everyday thing, somedays i can get in it, go for hours and not hear it 1 time.
    Seems to happen more in the cold mornings too..
    Could it be the pinion bearing?
  2. Nov 19, 2011 at 11:56 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    Has the rear differential gear oil ever been changed? Oh...and welcome aboard!
  3. Nov 19, 2011 at 12:07 PM
    Tacoma420
    Forrest
    Placerville CA
    Thats one thing i never have got changed, for 120k+ miles.
  4. Nov 19, 2011 at 12:26 PM
    Madjik_Man
    Colorado Front Range
    Great thread title.
    Sorry I have nothing more to add than that sophomoric observation.
  5. Nov 19, 2011 at 12:27 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    That is the sound of you pulling your third member out
  6. Nov 19, 2011 at 2:43 PM
    Tacoma420
    Forrest
    Placerville CA
    Well i got the rear diff fluid changed today, it looked pretty damn black, and there wernt any shaving in there, just a couple little ones stuck on the magnet of the drain hole.
    But im still getting the noise..
    What could it be? Any idea besides me not changing my fluid forever? lol
  7. Nov 20, 2011 at 7:14 AM
    Tacoma420
    Forrest
    Placerville CA
    Well it seems not many others were having this problem sense i didnt really get any other idea's.
    Well thanks for trying people, i guess ill just put up with the noise until something breaks, then ill know what it was.
  8. Nov 20, 2011 at 6:49 PM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    check the gear pattern or the axle bearings in the end of the tubes. or grease the driveshaft too
  9. Nov 20, 2011 at 7:37 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I had a humming accompanied with a vibration when my u-joints went bad.
    any strange vibrations with the humming?
  10. Nov 21, 2011 at 4:03 AM
    Tacoma420
    Forrest
    Placerville CA
    Yes, i had cab shaking vibration going on, and thats what made me change the U-joints first.
    Which the u-joints solved that no problem.
    Its the driveshaft with 4 U-joints, and they are all new joints.
    But i still get that stupid humming noise, which alot of people pointed me toward Carrier Bearing, or Pinion Bearing.
    Which both are pretty expensive jobs to get done, so sorta looking for more of a direct reason of the problem.
  11. Nov 21, 2011 at 8:22 AM
    TacoMX
    Jonathan
    Deltona, Florida
    carrier bearing is extremely easy labor wise compared to a pinion bearing if it ends up being that.
