Strange noise from front-end
Discussion in 'Technical Chat' started by jsmckinney, Apr 28, 2008.
  1. Apr 28, 2008 at 2:50 PM
    jsmckinney
    jsmckinney [OP] Member
    Arkansas
    2008 Tacoma TRD
    I have a 2008 Tacoma TRD double cab, purchased in January. Lately I have been hearing a banging noise coming from the front end possibly below my feet when driving. This noise happens when I turn either left or right of if I quickly pull the wheel left or right. I have found nothing loose underneath but it seems to be getting worse. Anyone else have this problem? Any ideas?
  2. Apr 28, 2008 at 3:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    just a thought....but do you have nerf bars of some sort?? i have some on my truck, and one time,after getting my tires balanced, i was hearing/feeling a banging under my feet.....it turned out to be the mount for the nerf bar was up against the frame. i had to get a pry bar and move it off the frame a bit from where it shifted,and no more problems there.
  3. Apr 28, 2008 at 3:58 PM
    jsmckinney
    Arkansas
    2008 Tacoma TRD
    Tacomaman06, I do have nerf bars but I have checked them already and they are tight.
  4. May 5, 2008 at 7:11 AM
    jsmckinney
    Arkansas
    2008 Tacoma TRD
    Tacomaman06, You were exactly right. I was only feeling for looseness. My right nerf bar was contacting the body mount and ended up being the source of the noise. Thanks!
  5. May 5, 2008 at 12:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hey man, glad you figured it out, and glad it was a good, cheap fix:D!!!
