strange noise from trans
Discussion in 'Technical Chat' started by nickbroaddus, Apr 6, 2010.
  1. Apr 6, 2010 at 4:16 PM
    nickbroaddus
    nickbroaddus [OP] Active Member
    AC/NJ
    06 trd sport acc cab prerunner
    Well i brought my 06 in to a dealership today for an oil change. about an hour and a half later i left and went to run errands. after about an hour my truck started making strange noises. when i accelerated there would be a squeeking, metal scraping, ticking noise from the drivetrain, the squeek squeek squeek would get faster as i went faster but stopped when i pressed the clutch. once i shifted it would start again- slow at first then faster which makes me think its trans not driveshaft. im taking it back in tomorrow any advice will help
  2. Apr 6, 2010 at 4:20 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    i dont have anything come to mind atm. but check the oil just to be on the safe side
  3. Apr 6, 2010 at 4:41 PM
    nickbroaddus
    AC/NJ
    checked the oil, looked at underneath of truck everything looks fine. they did say they topped off all my fluids so that might have had something to do with it.
  4. Apr 6, 2010 at 4:47 PM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    check u joints for slop. i would hate to start dropping fluids if your gonna have it looked at tomorrow
  5. Apr 6, 2010 at 5:03 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    Check oil maybe you got the new retard mechanic and only put 2 quorts in the engine lol
  6. Apr 6, 2010 at 5:10 PM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    OP said he already did.. that was the first thing i told em
  7. Apr 6, 2010 at 5:12 PM
    tacomakid96
    Phil
    Out n' about
    2008 Tundra
    haha sorry didnt even read others replies
  8. Apr 12, 2010 at 12:17 AM
    guy06
    guy06 Member
    currently having this issue as well. After reading through these posts: http://www.tacomaworld.com/forum/2nd-gen-tacomas/58278-tsb-t-o-bearing-issue.html, I took it in to the dealership. Bottom line: throwout bearing is steel and pilot shaft is made of aluminum (bad combo since aluminum can't stand up to steel for long periods of consistent contact). t/o bearing grinds into pilot shaft with each revolution, wobbling, which creates the chirping noise. Trick is the dealership has to be able to replicate issue (chirping noise), and won't just take your word for it - and this is only if you have a warranty. Toyota was *supposed* to have a newly redesigned pilot shaft by FEB 10, but don't know if that pulled through. I'm as frustrated as everyone else. I'll let ya know how the inspection/repair turns out
  9. Apr 1, 2013 at 8:32 PM
    guy06
    guy06 Member
    Well, the "repair" didn't hold up. I'm heading back in for my 3rd fix of TOB issue. I'm buying the URD trans sleeve kit and a better clutch.
  10. Jun 27, 2013 at 10:22 PM
    guy06
    guy06 Member
    700 miles in and URD sleeve kit is holding up nicely. I know that doesn't mean shit in terms of TOB issue, but thought I would drop a line....I'll be keeping tabs on this one, no doubt.
