Strange noise under full boost
Discussion in '4 Cylinder' started by US Marine, Mar 3, 2018.
  1. Mar 3, 2018 at 12:57 AM
    US Marine
    US Marine [OP] Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    My 02 Tacoma is running a TRD Black case low boost 4.5psi supercharger which is a Eaton M68 model
    The engine only has 65k miles and the supercharger has about 40k on it . A couple weeks ago I started hearing a groaning sound under full boost only and can be heard inside the truck with windows rolled up . I had the serpentine belts replaced last year with maybe 3k miles on them
    Noticed the belts looked slightly glazed and some abnormal wear on them so today had them changed again along with the tensioner and idler pullies . The mechanic said the belt was slipping because of both pullies not keeping tension on the belt and both pullies were in need of replacement
    On the drive home I had no issues with the belts or pullies and was feeling good that the problem was solved . I then head up a steep hill and while under boost the groaning sound reappeared . once I crested the hill the noise stopped
    So what is making this noise ?? , I've checked the supercharger with a engine stethoscope at idle and no abnormal sounds can be heard
  2. Mar 3, 2018 at 1:38 AM
    US Marine
    Chuck
    Gallatin Tennessee
    Doing more research , could I have a bad bypass valve ??
