Strange noise when turning off truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Minny Taco, Apr 26, 2016.
  1. Apr 26, 2016 at 11:49 AM
    Minny Taco
    Minny Taco [OP] For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    2015 Off-Road.. When I turn the key off it makes a "whirring" sound for a few seconds. I don't believe there's a problem, I'm just curious to know what it is. Is it just venting accumulated awesomeness?
  2. Apr 26, 2016 at 11:50 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Normal...on the newer trucks it's something to do with emissions i believe.
  3. Apr 26, 2016 at 11:54 AM
    JeffP213
    JeffP213 I used to do mods. I still do, but I used to, too
    Jeff
    Central, VA
    15 TRD OR
    Air induction system aka smog pump. Mine does it too
  4. Apr 26, 2016 at 11:58 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    My '15 OR 4X4 wizzes, pops, and hisses when you shut it off, all emission stuff.
  5. Apr 26, 2016 at 12:00 PM
    Minny Taco
    Minnesota
    OK that explains it, thanks.
    Silver Sky Metallic FTW!
    JeffP213[QUOTED] likes this.
  6. Apr 26, 2016 at 1:19 PM
    glitcheffect7
    glitcheffect7 Well-Known Member
    Maine
    2014 Tacoma 6 cyl 6 spd sr5 access cab
    None, stock
    My 2014 makes a sort of clunk sound. I've listened to other tacomas from many different years and seems to be present on all of them.
  7. Apr 26, 2016 at 2:49 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    It's the Storm Trooper mode powering down
    TRP and ManBeast like this.
  8. Apr 26, 2016 at 3:15 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    2012+ V6 trucks saw the introduction of the Air injection pump for emissions. (I4 trucks had them since 05). In 2013 the system saw the introduction of the shutdown purge (which is what you are hearing). This is to help clear any moisture that may of built up in the pump and exhaust header valves so they do not fail.
    The Air injection pump only runs on startup (2012+) and shutdown (2013+) v6 trucks and only does it on startup at temps above ~ 38*F
    a400ryan and Minny Taco[OP] like this.
  9. Apr 26, 2016 at 4:07 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Yep normal noise
  10. Apr 26, 2016 at 6:05 PM
    I3uller
    I3uller Well-Known Member
    Too far South
    Tacoma world ladies and gentlemen. What a place.
