Strange "Pinging" at low rpm's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jross20, Apr 26, 2018.
  1. Apr 26, 2018 at 3:34 PM
    #41
    eon_blue
    Azusa, CA
    It very well could if you're dealing with excessive carbon buildup as a possible culprit. Can't hurt to try (hopefully, haha).
  2. Apr 26, 2018 at 3:35 PM
    #42
    eon_blue
    Azusa, CA
    I would also do a few other basic things while you're at it like cleaning the throttle body (take it off and spray it with TB cleaner/wipe the gunk out of it) and clean the MAF sensor. Assuming these are simple DIY tasks on the 2nd gen like they are on 1st gens.
  3. Apr 26, 2018 at 3:38 PM
    #43
    jross20
    jross20 [OP] Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    I know how to clean the MAF, honestly I was afraid to touch the throttle body... do you know if there is a guide somewhere for it?
  4. Apr 26, 2018 at 3:39 PM
    #44
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Top Tier
  5. Apr 26, 2018 at 3:40 PM
    #45
    eon_blue
    Azusa, CA
    I'll have to let someone else chime in on that, I'm not familiar with how the 2nd gen one works.
  6. Apr 26, 2018 at 3:40 PM
    #46
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    These trucks ping, mine has done it since new on 87 octane. I have to run 93 in order for it to go away, Dealer even completed the pinging TSB for me and it helped some but its still there. Try some 93 and see if it goes away.
  7. Apr 26, 2018 at 3:41 PM
    #47
    eon_blue
    Azusa, CA
    dang wish we got 93 here in SoCal, highest we have is 91. Then again, 91 is $4/gallon right now so I'd hate to think of what 93 would cost.
  8. Apr 26, 2018 at 3:54 PM
    #48
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Ah gotcha. That is surprising.
  9. Apr 26, 2018 at 4:02 PM
    #49
    Plain Jane Taco
    USA
    Yep. It is. But TT fuels exceed the minimum mandated detergents requirements....and Costco apparently does as well.
  10. Apr 26, 2018 at 4:18 PM
    #50
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Use this one with the straw hose. Youtube it, it's not difficult.
  11. Apr 26, 2018 at 4:23 PM
    #51
    taco2010trd
    Tampa, Florida
    jross20[QUOTED][OP] likes this.
  12. Apr 26, 2018 at 5:28 PM
    #52
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Yeah I'm right around $3.20 now for 93, it hurts but its the only thing this truck wont ping on. I might as well own a diesel as its cheaper then 93 lol.
    jross20[OP] likes this.
  13. Apr 26, 2018 at 9:17 PM
    #53
    jross20
    Georgia
    Yeah I refuse to pay the rip-off prices of premium. All gas should just be a higher octane by default , would be so much better for everyone lol
  14. Apr 26, 2018 at 10:46 PM
    #54
    Nalex
    Nalex Well-Known Member
    2012 Tacoma DC TRD OffRoad
    There is a tsb for that noise. Eco reprogramming/flash or something like that
  15. Apr 27, 2018 at 5:48 AM
    #55
    jross20
    Georgia
    Yes but the issues are that it seems to be aimed at 2012+ models and also .. That doesn't explain why my taco just started doing it.
    So on the way home last night I drive normally and really only got her to do it once. But it was a lot less. I floored it a bit on two straight away close to my house to see if she just needed to breath. Annoying that 3rd to 4th slipped once a but but what can you do? Haha
    I will see of she does it again today.
  16. Dec 17, 2018 at 8:32 PM
    #56
    Chris_TRDTaco
    Chris_TRDTaco Member
    ‘04 TRD OR Prerunner, ‘23 TRD OR 4x4
    TRD Supercharger/ 5100’s/ 16x8 wheels/ 265/75/16 KO2’s
    How did you fix the lean problem? I put brand new knock sensors and harness and thought that was the problem. I always run 91 cause of the Trd supercharger and still at around 2k rpms i get that sound. Did you do tunning?
  17. Dec 17, 2018 at 8:44 PM
    #57
    eon_blue
    Azusa, CA
    Added the URD 7th injector kit...it adds more fuel to the mix via the supercharger intake and helps richen the fuel mixture.
    Sounds like you need a fuel modification as well...7th injector or a methanol injection kit, or bigger injectors, etc. It's a common problem with the 3.4l and boost
  18. May 16, 2019 at 11:03 AM
    #58
    thumper500
    thumper500 Member
    2013 Tacoma 4WD TRD Sport
    I always run Top Tier gas in my 2013 Taco V6 but still had the spark knock at high outside Temp. Shouldn't have to run higher octane to get rid of it either. I had the ECU reprogrammed per TSB and no more spark knock with 87 Octane.
  19. May 16, 2019 at 11:05 AM
    #59
    thumper500
    thumper500 Member
    Yes the TSB mod of ECU fixed mine, 87 octane no problem.
  20. May 16, 2019 at 11:10 AM
    #60
    thumper500
    thumper500 Member
    Are you running the 4.0 V6 with oil filter opening facing down? If so, the Fram was probably draining after shutdown and needed to fill back up when restarted. The OEM filter has an anti drain back valve which keeps the filter full after shutdown.
    jross20[OP] and BassAckwards like this.
