Strange popping noise from front end
Discussion in '3rd Gen. Tacomas (2016-2023)' started by brendanwebster911, Jan 27, 2017.
  1. Jan 27, 2017 at 5:33 AM
    brendanwebster911
    brendanwebster911 [OP] Well-Known Member
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    ive recently been getting popping noises from my front left suspension, sometimes the same noises come from the right too. It sounds just like a loose sway bar. But, I've checked and re checked that.
    The popping noises normally sound off when I hit small bumps or dips. It's very apparent while turning and hitting a small dip.
    I've already done tons of searching. I've re torqued my LCA bolts, swaybar end links and mounting brackets, and checked just about everything else. It's been 2-3 days of wrenching and trying to find a fix. I'm running a 2" lift via fox 2.5 coilovers in front. Any other ideas on what I can check out?
  2. Jan 27, 2017 at 5:33 AM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    2016 DCSB with 19,000 miles
  3. Jan 27, 2017 at 5:37 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Bad body mount bushings, especially at the radiator crossmember, is a common cause of your symptoms.
  4. Jan 27, 2017 at 5:39 AM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    I'll check that. Didn't think of that at all. I've been looking mostly at moving suspension parts.
    Thanks!
  5. Jan 27, 2017 at 5:53 AM
    splitbolt
    NW Arkansas
  6. Jan 27, 2017 at 5:57 AM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
  7. Jan 27, 2017 at 6:00 AM
    splitbolt
    NW Arkansas
    Yes; the consensus is they are not properly installed/torqued from the factory.
    I'm at 10,000; getting ready to do mine...
    shakerhood likes this.
  8. Jan 27, 2017 at 6:03 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    I've got the same thing on my second gen, I haven't done it yet but someone found that on his the lower shock bolt was over tightened and caused it to bind over little bumps especially when turning.
    brendanwebster911[OP] likes this.
  9. Jan 27, 2017 at 6:06 AM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Nice!
    Thanks a lot! I'm def looking into that after I get out of work!
  10. Jan 27, 2017 at 8:56 AM
    M80 taco
    M80 taco Toyota tank
    NEW MEXICO
    2017 inferno or short bed
    None
    I noticed mine these past few days, especially when it's colder out.its noticeable when turning right, popping coming from passenger front fender. also My front end has vibrations from driving down my little dirt road.
  11. Jan 27, 2017 at 8:59 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I'm getting a similar noise too and I can feel it through the floor boards. It's only happened a handful of times when it's been under 10 degrees out.
    2017 with 3k miles...
  12. Jan 28, 2017 at 5:22 AM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Thanks everyone.
    Ordered a set of the energy suspension body mount bushings. Hopefully that'll fix things up!
  13. Jan 28, 2017 at 6:33 AM
    ticric
    ticric Member
    Eric
    Québec , Canada
    16 trd sport
    I have the same symptoms as yours and it was the radiator bushing that sit on the frame , i have loose the bolt of the bushing , turn the bushing a little ,tightened the bolt and the problem was gone .
    The noise was present when the front wheel ,left or right,hit a bump and resonate in the floor...hope it helps..
  14. Jan 28, 2017 at 6:35 AM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Nice!
    Super excited to do this and get rid of that noise!
  15. Jan 28, 2017 at 6:37 AM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Is there any page on here you used to get the the bushing? A write up or anything? I'm curious on the easiest way to get to them
  16. Jan 28, 2017 at 6:39 AM
    splitbolt
    NW Arkansas
    Post #5; I linked a thread.
  17. Jan 28, 2017 at 6:46 AM
    ticric
    ticric Member
    Eric
    Québec , Canada
    16 trd sport
    For my case ,i didnt change the bushings, just loose the bolt and reseat the bushing on the frame and tighted up,i have also check the bolt of the frame that support the radiator,i think its 2 or 3 X 10mm on both side that goes into the front wheel well behind the headlight they where loose....
    Its a little hard to get to bushing ,because the nut is under the wheel well near the upper suspension arm and you need another tool to block the bolt ....
    My english is not perfect sorry guys...
  18. Jan 28, 2017 at 6:51 AM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    My bad. Found that.
    Can't wait to get my new bushings
  19. Jan 28, 2017 at 2:34 PM
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    I read so much worse from born and raised Americans. I understood what you typed just fine.
  20. Jan 28, 2017 at 3:37 PM
    ticric
    ticric Member
    Eric
    Québec , Canada
    16 trd sport
    :rofl:Thanks!
