Strange sound from engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by dparoskie, Jul 23, 2008.
  1. Jul 23, 2008 at 2:38 PM
    dparoskie
    dparoskie [OP] Member
    va
    01 tacoma
    I have a pinging/ gurgling sound from the engine when it’s under any kind of load. Brought it into the shop and they clean the mass air flow sensor and it helps reduce it a little but it comes right back. Its acts up more on hot days and there is a drop in horsepower. Anybody know what’s going on with it or how to fix this problem?
  2. Jul 23, 2008 at 4:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you may want to try running a tank of mid grade or premium. slunds like its pinging due to fuel grade. you also may want to clean the throttle body and maybe the pcv valve too.
  3. Jul 23, 2008 at 4:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You also may want to run some Seafoam thru the system. If none of that works, it could be your knock sensor. :)
  4. Jul 23, 2008 at 4:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, and a side note, if you do seafoam, go thru the brake booster line, its alot easier doing it that way, and it'll feed the whole intake and all.:)
  5. Jul 23, 2008 at 9:46 PM
    backwoodking
    backwoodking Well-Known Member
    Thousand Oaks/Southern CA
    3.4 V6 Deck Plate and Cut Turn-Down
    Deck Plate, Hitch, Cut Turn-Down Exhaust, Tint, Clear Corners, Shell, Full Size bed in the pickup, Hopefully More Soon
    Yeah I would say this sounds like a pinging from carbon deposits on your valves. when they get hot they tend to cause pinging sounds with higher mileage engines. Especially under load or when it is hot. It helps to put better gas in and switch to a lower gear when going up a hill or hauling loads. A fuel injector cleaner might also help
  6. Jul 25, 2008 at 10:02 AM
    Thunder
    Thunder Active Member
    Portland, Or
    Tacoma
    bpu's
    When was last time you did basic maintenance stuff?
    A new cap & rotor, plugs and wires, etc can often bring your rig back to life.
    +1 on trying some premium gas...especially if you've got some substantial mileage on your ride...
  7. Jul 25, 2008 at 11:08 AM
    AFBombdude
    AFBombdude Member
    Litchfield, AZ
    '01 PreRunner SR5
    Bone Stock for now
    +1
