Strange sound when I shut of engine?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TerribleTT, Jan 12, 2014.
  1. Jan 12, 2014 at 8:36 AM
    TerribleTT
    TerribleTT [OP] Member
    Thomas
    Buffalo NY
    2013 TRD Sport
    TRD Supercharger, TRD Pro Wheels, BFG KO2 tires, 3" Toytec Boss Pro lift, Boss Pro rear leaf springs - comp assembly, Cree LED light bars in front, Toyota TRD pro grill, TRD OEM running boards, TRD bed mat, under hood + bed LED lighting, tailgate lock, Dimple magnetic drain plugs - rear + front diffs, trans case, transmission, oil pan, truxedo bed cover, 12,000 pound warn winch (not in pics yet, and some TRD emblems so far.
    Hi Guy's my name is Tom and I'm new to TW. I wanted to try a post or two so I get used to navigating the site. I do have a question though. I have a 2013 Tacoma TRD Sport double cab with 400 miles on it so far. I also have a 2012 Tacoma TRD Sport limited with 9,800 miles. I have no issues with the 2013 but when I shut the engine off it makes a weird vacuum type sound for a split second? I only hear this noise as soon as I shut the engine off. I don't hear that on my 2012 when I shut it off? did Toyota change something on the 13's, and has anyone else heard this noise that I'm describing? I just don't know if it's normal or do I need to take it back to the dealer. The truck runs great and is quiet when it's running???? :confused: I appreciate any info. Thank you.
  2. Jan 12, 2014 at 8:42 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  3. Jan 12, 2014 at 8:44 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    It the heater returning to the "rest" state. Its normal.
  4. Jan 12, 2014 at 8:45 AM
    OffroadToy
  5. Jan 12, 2014 at 9:17 AM
    TerribleTT
    Thomas
    Buffalo NY
    2013 TRD Sport
    Thanks guy's for the info. I kind of figured it wasn't a major issue. Just a weird sound I've never heard on any of my previous Tacoma's?
